license file
nicclark
Post Fri Jul 11, 2014 12:12 pm
license file
Having some trouble with my license file and on line server stating error. Noticed when I went to log in online at serviio server.
"MediaBrowser is only available in the pro edition." So went to console and tried many time to upload license file, if I clicked on as license file the file greyed out. ok don't know whats up. The file is attached below. Thanks, nic.
nicclark
Post Fri Jul 11, 2014 1:08 pm
Re: license file
When you get to part with license file for upload don't get the ok to do so. Don't have a bunch of time. So just a fix to the license. Thanks, nic.
nicclark
Post Sun Jul 13, 2014 12:17 pm
Re: license file
I am also having some issues the way the console app is not performing. "Presentation" preferences. When using the drop down for the 3 choices, nothing seems to change online. I would like some of course to be removed. The "online" and some others for ease of use. I would think the "disable" would do this but does nothing. I have done save and stop server and restart, with no changes at all. Also would like to add playlists and have not found any way to do so. 10.6.8. mac. P.S. I have many categories disabled and if you go there and see they are not.
Post Sun Jul 13, 2014 3:54 pm
Re: license file
Presentation settings don't work in MediaBrowser yet.
Return to General discussion
