New version
gustavoas
Post Mon Jan 04, 2010 9:25 pm
New version
I'm anxious for the coming versions. I see that 0.3.1 is the next coming but I'm really looking forward for 0.4 (with Transcoding and Music Video browsing). Any idea or estimated date to have them released?? I will be very glad to test them :-D
Post Tue Jan 05, 2010 9:23 am
Re: New version
Hi, I was busy over the Christmas period, but should be able to release 0.3.1 sometime this week. 0.4 is quite packed with new features, I don't think I'll be able to give you anything to test before the end of January.
gustavoas
Post Mon Feb 01, 2010 9:40 pm
Re: New version
0.3.1 is working very well here! Now I'm very anxious for 0.4 with transcoding, if this works well I'll stop using 3 different media servers at the same time :-)
Post Tue Feb 02, 2010 12:18 am
Re: New version
Doing my best here ;-) Something is shaping up, I'll need some beta testers because it'll be a hard work to make it work flawlessly.
Stand001
Post Tue Feb 02, 2010 7:03 am
Re: New version
Hello
I can help you to do betatesting, i really like your product and I have a Samsung 55", PS3, Xbox 360, Windows Homeserver
stephan.andersson@hotmail.se
regards
Stephan
Post Tue Feb 02, 2010 10:07 am
Re: New version
WHoever wants to betatest, send me a PM and I'll send you details of a download once it's ready.
ultratoto14
Post Thu Feb 04, 2010 10:33 am
Re: New version
Hi Zip, did you succeeded to play a H264+AC3 ts or m2ts with the new version ? Did you find a solution to the problem with video speed up (related to 23.976 frame rate not supported for TS/M2TS on Samsung TVs) ?
Post Thu Feb 04, 2010 10:37 am
Re: New version
I haven't tried this. I don't even know about this problem ;-)
ultratoto14
Post Thu Feb 04, 2010 8:16 pm
Re: New version
If you have a Samsung TV, try to stream a blu-ray m2ts to the tv.
First: The samsung tv does not recognize the audio ids, these ids are not the same as the usual ones in streaming. This results in no Audio on the TV.
Second: Try this same m2ts remuxed in a TS. In this case, the tv plays the video too fast if the framerate is 23.976. Changing framerate to 25 or 30 (Normal PAL and NTSC frame rates), now the video is well played.
I don't know if it's due to bad profiles or if the does not simply support this kind of streams.
I'm just surprised that 23.976 MKVs play just fine.
If you need ts and m2ts samples i can provide you samples. You can generate samples yourself with http://forum.doom9.org/showthread.php?t=134104.
If you don't know it, this tool help you in remuxing mkv to TS/M2TS. You can change frameRate and disable new bluray PES in on of the configuration options.
Post Tue Mar 09, 2010 9:41 pm
Re: New version
0.4 beta is out, PM me if you want to beta test
Return to Feature requests
