Serviio and LB650V compatibility
nnnesa
Post Wed Jul 23, 2014 8:44 pm
Hello all!
I am intrested in buying LG 32LB650V model. I am wondering if i can use serviio to stream movies and series (.avi and .mkv extensions) from my computer to tv?
Is serviio compatible with webOS platform?
I am currently using Samsung 32F5500 with serviio and it works great, and i want that on LG...
blase
Post Sun Jul 27, 2014 10:28 am
Re: Serviio and LB650V compatibility
hello nnnesa
I have a service at a LB730 and works fine, the problem comes with the webos SmartShare, it does not allow you to change languages ​​in mkv or avi and subtitle selection.
If you play files from USB no problems
Return to LG
