Update To Serviio 1.4.1.2 Not Working On Mac OS X 10.6.8
mikey8811
Post Tue Jul 29, 2014 8:40 am
Hi
I am currently using Serviio 1.2 on Mac OS X 10.6.8 with Java 6 fully updated.
I downloaded and unpacked 1.4.1.2 to my applications folder as a folder and so did not overwrite Serviio 1.2, copied the old Library file into it but cannot launch Serviio or Serviio Console. The error messages from Console are as follows
7/29/14 4:19:24 PM [0x0-0x15ea5e9].org.serviio.serviio-console[38497] Exception in thread "Thread-3" java.lang.NullPointerException
7/29/14 4:19:24 PM [0x0-0x15ea5e9].org.serviio.serviio-console[38497] at org.serviio.console.ServiioConsole$ShutdownHook.run(ServiioConsole.java:324)
7/29/14 4:28:14 PM [0x0-0x15f25f1].org.serviio.serviio-console[38529] Exception in thread "Thread-3" java.lang.NullPointerException
7/29/14 4:28:14 PM [0x0-0x15f25f1].org.serviio.serviio-console[38529] at org.serviio.console.ServiioConsole$ShutdownHook.run(ServiioConsole.java:324)
I can still use Serviio 1.2, which I moved to Desktop with no problems.
Please tell me what I am doing wrong and how I can rectify it.
Post Wed Jul 30, 2014 11:50 am
Re: Update To Serviio 1.4.1.2 Not Working On Mac OS X 10.6.8
Haven't got a MAC, but can tell you that the upgrade pre-version 1.3 to post 1.3 requires a library re-build. I suspect by copying the pre-1.3 library into the latest version of Serviio you are bypassing the re-build process and killing Serviio. Did it work prior to copying the old library in?
mikey8811
Post Wed Jul 30, 2014 12:16 pm
Hi
Thanks for that.
I tried again and it worked.
Maybe someone should correct the FAQ details about Library files.
mikey8811
Post Fri Aug 01, 2014 2:22 pm
Hi
After trying it for a couple of days, the earlier build worked better. This one keeps disconnecting and not being on the network intermittently.
Users browsing this forum: No registered users and 79 guests
