How to play a live stream on Sony Blu Ray Player (RTMP)?
deployedstream
Post Wed Jul 30, 2014 11:02 pm
I already have Serviio and its pretty good, but the problem is I cannot seem to be able to capture the stream link.
These are the two sites I'm trying to capture from;
http://www.zahistations.net/watch-cnn-i ... ional-live
and/or
http://www.filmon.com/tv/bbc-news
I got these two rtmp links for the second stream but non of them work in Serviio.
Xrtmp://live304.edge.filmon.com/live/?i
rtmp://mi1.gv.filmon.com:1935/live/defi ... low.stream
I read that they are not in the correct format. Can an expert please help?
Post Fri Aug 01, 2014 10:27 am
Re: How to play a live stream on Sony Blu Ray Player (RTMP)?
Did you try to add the to the console and click Check stream button?
deployedstream
Post Fri Aug 01, 2014 1:13 pm
zip wrote:Did you try to add the to the console and click Check stream button?
Yes. Every time there's an X. I got it once to work and saw a green tick with the BBC Link. I wish I hadn't stupidly deleted the link.
Post Sun Aug 03, 2014 11:44 am
What do you get when you try
FFmpeg -i "rtmp://....."
Return to User experiences
