Captions not showing: suported format?
Post Mon Jul 28, 2014 2:00 am
I have some recorded TV shows that contain closed captions. The default video file is .WTV (Windows Media Center). I used VideoReDo to edit the commercials out, and saved to .TS (MPEG2). The files play fine, but the captions don't appear. My Sony players will show in the info screen if captions are available, and these files don't show any. Here's the format within the file from MediaInfo:
Text
ID                                       : 528 (0x210)-1
Menu ID                                  : 1 (0x1)
Format                                   : EIA-708
Muxing mode                              : A/53 / DTVCC Transport
Muxing mode, more info                   : Muxed in Video #1
Duration                                 : 1h 51mn
Stream size                              : 0.00 Byte (0%)
Is this text format not supported?
The other captions issue is with Blu-ray rips using MakeMKV. The text info is in the file, and my player shows a caption track available, but if I select captions, nothing shows. MediaInfo shows this:
Text #1
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : The same subtitle format used on BDs/HD-DVDs
But if I have a Blu-Ray that was ripped with different software into M2TS format (MakeMKV works better, as the other software doesn't allow selected specific audio and captions tracks), the captions can be selected and they appear. Why the difference?
Post Wed Jul 30, 2014 11:53 pm
Re: Captions not showing: suported format?
Well, since no one has offered anything here, how about a different approach: is it possible to "remux" the captions? In other words, convert the text track to something that Serviio recognizes, without altering the video or audio tracks?
Post Wed Aug 06, 2014 9:57 pm
For embedded subs, Serviio normally serves then in the file as usual - then it's up to the player to recognize them and give you the options.
You could also enable extracting the embedded subs (in the console) - it only works for text based subtitles, changes them to srt and then serves as either external resource (where supported), or you could also enable burned in subs, which would then take that extracted srt and encode it into the video. I assume you don't want that though.
So I think option one is what you want, but you have to find the combination of container / sub format that will work.
Post Thu Aug 07, 2014 12:18 pm
zip wrote:For embedded subs, Serviio normally serves then in the file as usual - then it's up to the player to recognize them and give you the options.
Yeah, it seems that my players don't recognize the EIA-708 captions. I tried using CCExtractor to create an SRT, which works of course but now I don't have the options of turning the captions on and off. I typically only enable captions when watching late at night so I can keep the volume down.
I guess I need a way to take that SRT file and put it back into the video file. Looks like MKV is the best container for that, but I don't know what will merge them. Handbrake perhaps? I'll have to look at it. I start a 2 week vacation next week, so I'll have some time to experiment.
nonuser
Post Sat Aug 23, 2014 8:48 pm
I was trying to play files with separate subtitle .SRT files and they didn't show up. Enabling burned-in subs worked, thanks.
(PC to PS3)
Lowlander
Post Tue Aug 26, 2014 12:01 pm
atc98092 wrote:I need a way to take that SRT file and put it back into the video file. Looks like MKV is the best container for that, but I don't know what will merge them.
MKVToolNix should be the right tool for that job. It's free and very straightforward to use.
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
