tv sries showing up as movies
sparx
Post Sat Aug 16, 2014 6:55 am
I use swisscenter for meta data control, and my tv series shows up as tv series in this program. HOwever in servioo they all appear as movies?
they are all in a folder called tv series
sub folder is tv series name, sub folder og seasons and individual files below these as
title - S01E01 - name
what can be wrong in my setup?
TIA
Post Sun Aug 17, 2014 12:03 am
Re: tv sries showing up as movies
sparx wrote:I use swisscenter for meta data control, and my tv series shows up as tv series in this program. HOwever in servioo they all appear as movies?
TIA
There is a checkbox on the Presentation tab that says "Show Series in relevant categories only". If that is not checked, TV series will show up in the Movies folders as well. Make sure the box is checked. :D
sparx
Post Sun Aug 17, 2014 9:39 am
This box is already checked, so?
TIA[/quote]
There is a checkbox on the Presentation tab that says "Show Series in relevant categories only". If that is not checked, TV series will show up in the Movies folders as well. Make sure the box is checked. :D[/quote]
Post Sun Aug 17, 2014 7:00 pm
sparx wrote:This box is already checked, so?
TIA
Well, that fixed it for me. I'll have to leave it for someone else to troubleshoot.
sparx
Post Mon Aug 18, 2014 6:49 am
thanks.
yeah, my problem is that it only shows up in movies and not both places...
Post Tue Aug 19, 2014 11:12 am
Reading other sites (I'm not a Swisscenter user so excuse this if way off base) try enabling the option 'Download Extra Info' for your 'TV Series' category (whatever this means :-)). See if it helps (you may need to refresh the download?).
