Sony S370/BX37(&bravia?) FAQ?
dougri
Post Fri Feb 11, 2011 7:45 am
Is there some sort of FAQ or guide available for the Sony products? There seem to be a lot of common issues people are having that there are either easy solutions/workarounds to (sony menu structure oddities), inherent weaknesses to the hardware (problems with high bitrate DLNA), or things that might be solved in a future version of serviio.
I'm currently working through the stuttering audio/video issue with my BX37, and see some differing advice/experiences. I'd write an FAQ if I felt I knew the answers, but just getting started here, so probably not the one to do this particular FAQ ;)
Post Fri Feb 11, 2011 9:04 am
Re: Sony S370/BX37(&bravia?) FAQ?
Do you read this : viewtopic.php?f=11&t=425 the FAQ is at the end.
Do you read this viewtopic.php?f=5&t=1126&p=5340#p5344
dougri
Post Fri Feb 11, 2011 3:19 pm
thanks... I'll read through that more carefully, not sure why I did not see the FAQ section in the first page of posts.
