Serviio stops running on NAS
oNlyLuck
Post Sat Aug 16, 2014 11:37 am
Hi everybody,
I installed Serviio on my DS114. Unfortunately, it stops running randomly and I can't really figure out why. I've been reading, but was not able to find the reason why it's not working correctly.
I either start the server from package center or from Putty. When I start it using ssh, everything works fine until I close the Putty session. I attached the last log file. Maybe you guys can help me out or point me in the right direction.
Logfile
(185.07 KiB) Downloaded 667 times
Thank you very much in advance!
Stef
oNlyLuck
Post Mon Aug 18, 2014 8:04 am
Re: Serviio stops running on NAS
I finally got it working. At least when starting serviio using ssh. I used tmux in order to keep the process running when closing the terminal. Starting serviio from package center is not working. "ps" command shows that user serviio is running the serviio.sh and java, but server is not reachable by serviidroid.
I tried to add serviio to auto start when my NAS boots up, but this is not working. I used the serviio.conf way after I found helpful information in this forum. Unfortunately, it's not working properly, but thats another problem :)
