MAC problems with library
skiocink
Post Mon Aug 18, 2014 11:10 am
Hello guys,
I'm trying to use Serviio on my Mac Mini winch OSX Maverics but i'm going mad!!!
The Library won't upgrade if I add a new file in the right folder. Uninstalling and reinstalling back the Serviio (latest version) the library creates a new db and recognizes the new files.
ffmpeg file is the original from installation, I tried to upgrade it but the problem remains. Tried also to execute from /Applications/Serviio.App/Contents/MacOS/ : ffmpeg -i /.../.../filename.avi but my terminal says COMMAND NON FOUND.
This is the  log file with an strage error about ffmeg.exe!
2014-08-18 12:51:26,393 WARN [ProcessExecutor] Cannot retrieve results, output reader is null
2014-08-18 12:51:26,393 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/Volumes/Serviio/Video/Telefilm/Revolution/Revolution 2/REV216.ITA.TLOTS.mp4). Message: Unknown video file type.
2014-08-18 12:53:37,688 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-08-18 12:53:37,863 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-08-18 12:53:38,034 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-08-18 12:53:38,034 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-08-18 12:53:38,051 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/Applications/Serviio.app/Contents/Resources/Java/lib/ffmpeg.exe": error=2, No such file or directory
java.io.IOException: Cannot run program "/Applications/Serviio.app/Contents/Resources/Java/lib/ffmpeg.exe": error=2, No such file or directory
at java.lang.ProcessBuilder.processException(ProcessBuilder.java:478)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:457)
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:53)
at java.lang.ProcessImpl.start(ProcessImpl.java:91)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:452)
... 1 more
2014-08-18 12:53:38,052 WARN [ProcessExecutor] Cannot retrieve results, output reader is null
2014-08-18 12:53:38,052 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/Volumes/Serviio/Video/GDP_E170.wmv). Message: Unknown video file type.
2014-08-18 12:53:38,092 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/Applications/Serviio.app/Contents/Resources/Java/lib/ffmpeg.exe": error=2, No such file or directory
... 1 more
2014-08-18 12:53:38,093 WARN [ProcessExecutor] Cannot retrieve results, output reader is null
2014-08-18 12:53:38,093 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/Volumes/Serviio/Video/Telefilm/Revolution/Revolution 2/REV216.ITA.TLOTS.mp4). Message: Unknown video file type.
skiocink
Post Mon Aug 18, 2014 11:25 am
Re: MAC problems with library
latest info...my terminal running ./ffmpeg
MediaServerMac:MacOS DLNA$ ./ffmpeg -i /Volumes/Serviio/Video/GDP_E170.wmv
built on Jun 18 2013 11:47:55 with gcc 4.0.1 (GCC) (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-libfreetype --enable-fontconfig --enable-libass --enable-pthreads --enable-libx264 --enable-gpl --disable-mmx --extra-ldflags=-L/Users/MacAdmin/Desktop/build/target/lib --extra-cflags=-I/Users/MacAdmin/Desktop/build/target/include --extra-libs='-lpolarssl -lfreetype -lexpat -liconv'
[wmv3 @ 0x32e5400] Extra data: 8 bits left, value: 0
Input #0, asf, from '/Volumes/Serviio/Video/GDP_E170.wmv':
WMFSDKNeeded : 0.0.0.0000
DeviceConformanceTemplate: MP@ML
WM/WMADRCPeakReference: 32767
WM/WMADRCPeakTarget: 32767
WM/WMADRCAverageReference: 809
WM/WMADRCAverageTarget: 809
NumberOfFrames : 55943
WMFSDKVersion : 12.0.7601.17514
IsVBR : 1
Duration: 00:31:07.10, start: 0.000000, bitrate: 2381 kb/s
Stream #0:0: Audio: wmapro (b[1][0][0] / 0x0162), 44100 Hz, stereo, fltp, 440 kb/s
Stream #0:1: Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 720x480, 2000 kb/s, SAR 1:1 DAR 3:2, 29.97 tbr, 1k tbn, 1k tbc
irdet2
Post Sat Sep 06, 2014 1:38 pm
Hi!
I don't know if you still facing this issue but you might want to check this bug: https://bitbucket.org/xnejp03/serviio/i ... e-of-wrong
with the solution I 've submitted.
Regards,
G.
EDIT: Corrected URL
Users browsing this forum: No registered users and 94 guests
