live-flv fails
I have streams which ffmpeg identifies as live-flv rather than flv.
They run fine in ffmpeg but fail in serviio. Does live-flv support need to be added to serviio?
- Code:
014-08-19 17:01:50,012 DEBUG [FeedItemUrlExtractor] HaHaSport: Starting extraction of url for item: Tue 17:00-19:00 CA Rentistas vs Cerro Porteno|Copa Sudamericana
2014-08-19 17:01:50,489 DEBUG [FeedItemUrlExtractor] HaHaSport: call hqstream
2014-08-19 17:01:50,492 DEBUG [FeedItemUrlExtractor] HaHaSport: Extracted url for Tue 17:00-19:00 CA Rentistas vs Cerro Porteno|Copa Sudamericana
2014-08-19 17:01:50,492 DEBUG [FeedItemUrlExtractor] HaHaSport: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=rtmp://37.221.172.84/shqstream/yxubcn22lq4xkgz_ssta17pd66?keys=_kj3XKBK7QPoJ3Iagvd9SA&keyt=1408496508 swfUrl=http://filo.hqstream.tv/jwp6/jwplayer.flash.swf pageUrl=http://hqstream.tv live=1, thumbnailUrl=https://sites.google.com/site/hahaflags/uy.gif, expiresImmediately=true, cacheKey=hahasport_http://www.hahabar.com/20140819/v-haha_sport_1_name-873131-53f278b01aaa49.22176534.html, live=true, ]
2014-08-19 17:01:50,492 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmp://37.221.172.84/shqstream/yxubcn22lq4xkgz_ssta17pd66?keys=_kj3XKBK7QPoJ3Iagvd9SA&keyt=1408496508 swfUrl=http://filo.hqstream.tv/jwp6/jwplayer.flash.swf pageUrl=http://hqstream.tv live=1
2014-08-19 17:01:50,493 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib\ffmpeg.exe -analyzeduration 10000000 -i rtmp://37.221.172.84/shqstream/yxubcn22lq4xkgz_ssta17pd66?keys=_kj3XKBK7QPoJ3Iagvd9SA&keyt=1408496508 swfUrl=http://filo.hqstream.tv/jwp6/jwplayer.flash.swf pageUrl=http://hqstream.tv live=1
2014-08-19 17:01:55,016 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://37.221.172.84/shqstream/yxubcn22lq4xkgz_ssta17pd66?keys=_kj3XKBK7QPoJ3Iagvd9SA&keyt=1408496508 swfUrl=http://filo.hqstream.tv/jwp6/jwplayer.flash.swf pageUrl=http://hqstream.tv live=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:467)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:299)
... 2 more
- Code:
C:\Users\John>ffmpeg -i "rtmp://173.193.216.172/shqstream/yxubcn22lq4xkgz_ssta17
pd66?keys=2gNK9aconxy3-OvnYY4SbA&keyt=1408496489 swfUrl=http://filo.hqstream.tv/
jwp6/jwplayer.flash.swf pageUrl=http://hqstream.tv live=1"
ffmpeg version N-65341-g305f72a Copyright (c) 2000-2014 the FFmpeg developers
built on Aug 6 2014 12:58:50 with gcc 4.8.3 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --
enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-lib
modplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrw
b --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinge
r --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --en
able-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-
libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib
libavutil 52. 98.100 / 52. 98.100
libavcodec 55. 72.102 / 55. 72.102
libavformat 55. 51.101 / 55. 51.101
libavdevice 55. 13.102 / 55. 13.102
libavfilter 4. 11.102 / 4. 11.102
libswscale 2. 6.100 / 2. 6.100
libswresample 0. 19.100 / 0. 19.100
Server NGINX RTMP (github.com/arut/nginx-rtmp-module)
width 550.00
height 310.00
displayWidth 550.00
displayHeight 310.00
duration 0.00
framerate 25.00
fps 25.00
videodatarate 500.00
videocodecid 0.00
audiodatarate 48.00
audiocodecid 0.00
Input #0, live_flv, from 'rtmp://173.193.216.172/shqstream/yxubcn22lq4xkgz_ssta1
7pd66?keys=2gNK9aconxy3-OvnYY4SbA&keyt=1408496489 swfUrl=http://filo.hqstream.tv
/jwp6/jwplayer.flash.swf pageUrl=http://hqstream.tv live=1':
Server : NGINX RTMP (github.com/arut/nginx-rtmp-module)
displayWidth : 550
displayHeight : 310
fps : 25
profile :
level :
Duration: 00:00:00.00, start: 1313.470000, bitrate: N/A
Stream #0:0: Video: vp6f, yuv420p, 550x310, 512 kb/s, 25 fps, 25 tbr, 1k tbn
, 1k tbc
Stream #0:1: Audio: mp3, 22050 Hz, stereo, s16p, 49 kb/s
