Serviio-Ubuntu 14.04.1 LTS Brain Cramp
lafaverp
Post Wed Aug 20, 2014 11:50 pm
First, I apologize for people like myself who come from 20 years of Windows and find Linux to be like learning Swahili. So. after reading dozens of posts on Serviio installation I finally have the service running on Ubuntu 14.04.1 LTS. I am trying to get the Windows console to work. Service is running on server but when I run the Windows console I get:
"Cannot connect to Serviio server, it does not seem to be running. Exiting..." After reading the solutions I have checked the directory permissions which I believe are 777?
lafaverp@m8200:/etc/serviio$ ls -l
total 40536
[color=#FFFFBF]drwxrwxrwx 2 root root 4096 Aug 20 12:39 bin
drwxrwxrwx 2 root root 4096 Aug 20 12:32 config
drwxrwxrwx 2 root root 4096 Aug 20 12:32 legal
drwxrwxrwx 2 root root 4096 Aug 20 12:32 lib
drwxrwxrwx 2 root root 4096 Aug 20 12:32 library
-rwxrwxrwx 1 root root 3255 Aug 20 12:32 LICENCE.txt
drwxrwxrwx 2 lafaverp lafaverp 4096 Aug 20 12:50 log
-rwxrwxrwx 1 root root 10900 Aug 20 12:32 NOTICE.txt
drwxrwxrwx 2 root root 4096 Aug 20 12:32 plugins
-rwxrwxrwx 1 root root 3396 Aug 20 12:32 README.txt
-rwxrwxrwx 1 root root 40510 Aug 20 12:32 RELEASE_NOTES.txt
drwxrwxrwx 8 lafaverp lafaverp 4096 Mar 21 14:43 serviio-1.4.1.2
-rwxrwxrwx 1 root root 20701487 Mar 21 15:34 serviio-1.4.1.2-linux.tar.gz
-rwxrwxrwx 1 lafaverp lafaverp 20701487 Mar 21 15:34 serviio-1.4.1.2-linux.tar.gz.1
-rwxrwxrwx 1 lafaverp lafaverp 5 Aug 20 15:18 serviiod
Here is the derby.log: ( The highlighted lines are suspicious)
Wed Aug 20 12:50:23 PDT 2014 Thread[main,5,main] Cleanup action starting
ERROR XBM0H: Directory /etc/serviio/library/db cannot be created.
at org.apache.derby.impl.services.monitor.StorageFactoryService$10.run(Unknown Source)
at org.apache.derby.impl.services.monitor.StorageFactoryService.createServiceRoot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.createPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.createPersistentService(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.createDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.Driver20.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:571)
at java.sql.DriverManager.getConnection(DriverManager.java:233)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:59)
at org.serviio.MediaServer.main(MediaServer.java:116)
Cleanup action completed
java.sql.SQLException: Failed to create database 'db', see the next exception for details.
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
And the serviio.log
2014-08-20 12:50:22,432 INFO [MediaServer] ------------------------------------------------------------------------
2014-08-20 12:50:22,433 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f+)
2014-08-20 12:50:22,433 INFO [MediaServer] Petr Nejedly 2009-2014
2014-08-20 12:50:22,433 INFO [MediaServer] http://www.serviio.org
2014-08-20 12:50:22,433 INFO [MediaServer] Java 1.7.0_65-Oracle Corporation
2014-08-20 12:50:22,433 INFO [MediaServer] OS Linux amd64 3.13.0-24-generic
2014-08-20 12:50:22,434 INFO [MediaServer] File encoding: UTF-8
2014-08-20 12:50:22,434 INFO [MediaServer] Headless mode enabled: true
2014-08-20 12:50:22,434 INFO [MediaServer] User: lafaverp
2014-08-20 12:50:22,434 INFO [MediaServer] User home dir: /home/lafaverp
2014-08-20 12:50:22,434 INFO [MediaServer] Temp dir: /tmp
2014-08-20 12:50:22,434 INFO [MediaServer] ------------------------------------------------------------------------
2014-08-20 12:50:22,576 INFO [WebServer] Socket buffer set to 65535 bytes
2014-08-20 12:50:22,578 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-08-20 12:50:22,625 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-08-20 12:50:22,625 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-08-20 12:50:22,640 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-08-20 12:50:22,661 INFO [DatabaseManager] Using DERBY database language
2014-08-20 12:50:23,052 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
So that's about all I can figure out. Any help would be greatly appreciated.
Post Thu Aug 21, 2014 5:14 pm
Re: Serviio-Ubuntu 14.04.1 LTS Brain Cramp
Server didnt start, because the db cannot be created. probably write access rights are missing.
lafaverp
Post Fri Aug 22, 2014 7:00 am
thank you for the quick response. Sorry to be dense, but doesn't 777 for the directory cover that? ... or not?
Post Thu Aug 28, 2014 8:49 pm
yes it should. is it the same for the sub directories of the library folder?
Users browsing this forum: Google [Bot] and 46 guests
