PACKAGE: Serviio 1.5 for QNAP NAS (ARM & x86 Intel)
eXistenZe
Post Sat Jul 05, 2014 5:11 pm
Re: PACKAGE: Serviio 1.4 for QNAP NAS (ARM & x86 Intel)
Hey guys...
Getting a lot of problems with my second attempt on serviio with my qnap ts212.
Installed jre fine, installed Serviio 1.4.1.2 Revision 1 fine too.
When opening serviio console it takes about 40 seconds just to open. When I try to save something it gives me an error "Error: timeout HTTP response code:0 timeout"
My log claims two errors:
WARN [ServiioStatusService] ConversionException occured. Returning error code 500 to the REST layer. Message: Zero length string : Zero length string
WARN [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsubs) will not work.
Any insights?
eXistenZe
Post Sun Jul 06, 2014 12:05 pm
Ok... After a lot of trials, I narrowed it to an incompatibility with download station. If I enable it, serviio no longer works (no streaming, WebUI is slow and non responsive 99%).
Anyone figured this one out?
It does not seem to be an hardware limitation since both CPU and memory are mostly free (I don't use transcoding)...
Xmantium
Post Tue Jul 08, 2014 11:52 pm
Been so busy with working double shifts and World Cup, i will look at this further.
My Serviio on my ARM has been running solid, web ui working fine. BTW subtitles are not enabled in ARM as the chip cannot handle transcoding video.
I'll do a new guide and make sure all the links work
Xmantium
Post Sat Aug 23, 2014 6:40 pm
Since QNAP provide their own JRE builds from the AppCentre, all new Serviio QPKG builds will support this.
Manual ARM installer can be found here - http://www.qnap.com/i/uk/app_center/con ... key=319496
Im made a new revision to support the Qnaps JRE_ARM package, no more need to manually install JRE
https://bitbucket.org/Xmantium/serviio- ... m-x19.qpkg
hstorey219
Post Mon Dec 08, 2014 11:24 pm
Thank you for the package!!! this is great
sfj13
Post Mon Dec 15, 2014 10:24 pm
Would this package work for the TS-451?
Xmantium
Post Mon Dec 15, 2014 10:52 pm
This model uses different type of cpu, check the qnap forums how to mod a QPKG.
I'm in the process of a big house move. My server is still in boxes :(
rajneilg
Post Tue Dec 23, 2014 12:12 pm
Hi All,
I have spending days trying to get Serviio to work on my Qnap TS-212 and am really hoping you guys can give me a hand to get this working.
I am on QNAP firmware version 4.0.2.
So far:
1. Have installed JRE_ARM 8.0.1 from QNAP App Center
2. Installed Serviio V1.4.1.2-R2
3. When I goto the Serviio console page, it's really slow and in the serviio.log file it's saying:
[ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
This is an extract from the log file:
2014-12-23 20:17:09,993 INFO [MediaServer] ------------------------------------------------------------------------
2014-12-23 20:17:10,002 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f+)
2014-12-23 20:17:10,004 INFO [MediaServer] Petr Nejedly 2009-2014
2014-12-23 20:17:10,004 INFO [MediaServer] http://www.serviio.org
2014-12-23 20:17:10,005 INFO [MediaServer]
2014-12-23 20:17:10,005 INFO [MediaServer] Java 1.8.0-Oracle Corporation
2014-12-23 20:17:10,005 INFO [MediaServer] OS Linux arm 2.6.33.2
2014-12-23 20:17:10,006 INFO [MediaServer] File encoding: UTF-8
2014-12-23 20:17:10,050 INFO [MediaServer] Headless mode enabled: true
2014-12-23 20:17:10,051 INFO [MediaServer] User: admin
2014-12-23 20:17:10,051 INFO [MediaServer] User home dir: /share/homes/admin
2014-12-23 20:17:10,051 INFO [MediaServer] Temp dir: /root/.serviio/tmp
2014-12-23 20:17:10,052 INFO [MediaServer] ------------------------------------------------------------------------
2014-12-23 20:17:12,126 INFO [WebServer] Socket buffer set to 65535 bytes
2014-12-23 20:17:12,181 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-12-23 20:17:13,945 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-12-23 20:17:13,948 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-12-23 20:17:14,160 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-12-23 20:17:15,138 INFO [DatabaseManager] Using DERBY database language
2014-12-23 20:18:52,581 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2014-12-23 20:18:52,802 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2014-12-23 20:18:52,798 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2014-12-23 20:18:52,795 WARN [ServiioStatusService] ExceptionInInitializerError occured. Returning error code 500 to the REST layer. Message: null
2014-12-23 20:18:52,580 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2014-12-23 20:18:52,797 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2014-12-23 20:18:52,795 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2014-12-23 20:18:52,796 WARN [ServiioStatusService] PersistenceException occured. Returning error code 500 to the REST layer. Message: Cannot read list of all stored renderers
2014-12-23 20:18:57,576 INFO [DBSchemaUpdateExecutor] Updating DB schema
2014-12-23 22:16:07,953 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2014-12-23 22:16:08,266 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2014-12-23 22:16:08,265 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
and it keeps going.
And when I access serviio via nasip/serviio I am getting the following messages:
WARNING: Web UI is optimized for Serviio v1.3 but v was found. There may be a loss of functionality. Please consider updating.
Notice: Undefined variable: startDisabled in /share/MD0_DATA/.qpkg/Serviio/web_ui/view/status.php on line 13
Notice: Undefined variable: stopDisabled in /share/MD0_DATA/.qpkg/Serviio/web_ui/view/status.php on line 14
I've tried the following but it hasn't made a difference:
1. Chmod 777 /share/MD0_DATA/.qpkg/Serviio/web_ui
2. Chmod 777 /share/MD0_DATA/.qpkg/Serviio/opt/bin
Could someone please help me troubleshoot this?
Thank you very much in advance.
Regards,
Raj.
Xmantium
Post Tue Dec 23, 2014 1:20 pm
This sometimes happens when you first install Serviio or restart your NAS. I use the app Qmanager to sort this.
If u get errors, turn off Serviio in app centre, wait a minute and switch it on.
Works every time
rajneilg
Post Wed Dec 24, 2014 11:15 am
Thanks Xmantium! That fixed that up as I can login and it's a lot quicker accessing the console. However, the service doesn't seem to be starting and when I add a library location and save, it says that it's saved but if I go back to the tab, the folder location is not there anymore.
Also intermittently, it gives me an error saying 'Error: timeout HTTP Response Code: 0 timeout'
What can I check? This is what the log shows:
2014-12-24 19:14:53,388 INFO [DatabaseManager] Using DERBY database language
2014-12-24 19:14:52,639 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-12-24 19:14:52,082 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-12-24 19:14:52,080 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-12-24 19:14:49,404 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-12-24 19:14:49,149 INFO [WebServer] Socket buffer set to 65535 bytes
2014-12-24 19:14:40,029 INFO [MediaServer] ------------------------------------------------------------------------
2014-12-24 19:14:40,029 INFO [MediaServer] Temp dir: /root/.serviio/tmp
2014-12-24 19:14:40,029 INFO [MediaServer] User home dir: /share/homes/admin
2014-12-24 19:14:40,028 INFO [MediaServer] User: admin
2014-12-24 19:14:40,028 INFO [MediaServer] Headless mode enabled: true
2014-12-24 19:14:39,519 INFO [MediaServer] File encoding: UTF-8
2014-12-24 19:14:39,516 INFO [MediaServer] OS Linux arm 2.6.33.2
2014-12-24 19:14:39,515 INFO [MediaServer] Java 1.8.0-Oracle Corporation
2014-12-24 19:14:39,515 INFO [MediaServer] http://www.serviio.org
2014-12-24 19:14:39,514 INFO [MediaServer] Petr Nejedly 2009-2014
2014-12-24 19:14:39,514 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f+)
Xmantium
Post Wed Dec 24, 2014 11:37 am
Hmm... not sure why you can't add folders.
Maybe it's the web ui, can you use the Windows console or android app instead -
viewtopic.php?f=14&t=17123#p92576
If that doesn't work can you do a fresh install, make sure is the ARM version.
rajneilg
Post Wed Dec 24, 2014 1:05 pm
Tried the following:
1. Connecting with the existing Serviio Console on my laptop (as I have another Serviio server instance running) after changing the C:\Program Files\Serviio\bin\ServiioConsole.exe.vmoptions file and adding the line -Dserviio.remoteHost=192.168.0.2/serviio
The console won't even open after adding the line.
2. With the Android app, it automatically picks up my laptop instance and when I manually add 192.168.0.2/serviio and try to connect, I get the error HTTP Code: 404
3. I've re-installed Serviio again using the following qpkg - Serviio_1.4.1.2-R2_arm-x19.qpkg and tried 1 and 2 again without any luck.
What do I do now?
Merry Xmas and thanks for your help and quick responses!
Xmantium
Post Wed Dec 24, 2014 1:14 pm
Please follow the instructions properly.
It's Dserviio.remoteHost=192.168.0.2, not Dserviio.remoteHost=192.168.0.2/serviio
Android app, don't add the /serviio
Xmantium
Post Wed Dec 24, 2014 1:21 pm
To all QNAP users, unfortunately I won't be building Serviio 1.5 package if it launches end of this month.
I've just moved to a new build house, won't have internet till 15th January 2015 :cry:
rajneilg
Post Wed Dec 24, 2014 1:32 pm
Sorry - I didn't mention that I did try both options. But i'll try it again.
rajneilg
Post Wed Dec 24, 2014 1:57 pm
So with ServiiDroid, I get the message:
'Failed to open a connection to a server
Failed to connect to 192.168.0.2 port 23423) after 5000ms: IsConnected failed: ECONNREFUSED.'
I've connected to the qnap via winscp and I have made sure that the serviio server is started. It's just a matter of connecting to the damn thing.
Xmantium
Post Fri Dec 26, 2014 5:54 pm
Open your ports 23423 on your router
Read your router manual to do this
alanimal
Post Thu Jan 15, 2015 10:47 pm
Howdy! Can someone tell me if I can install Serviio onto my TS-251 that I just bought after my home media server died?
I have been using Serviio for years on my media server, have now moved to a Qnap NAS.
ferrvittorio
Post Mon Jan 19, 2015 3:07 pm
onwing a TS212, correctly installed Jre and Serviio, daemon is running, and .. cannot access webui
And cannot figure out where the problem is
Vittorio
EDIT
solved
Xmantium
Post Mon Jan 19, 2015 8:21 pm
I think the issue lies in the startup script, by going in the app centre, on Serviio, switch off, wait 30 seconds, switch on Serviio, always works.
