Sun Aug 24, 2014 10:59 pm by Xmantium
mp4 is not a format that you can transcode to stream straightaway, that's why Serviio don't support it, it simply doesn't work.
The only way you can watch a non-mp4 file is convert it FULLY using third party encoders.
If it's mkv files, you can quickly remux (keeps video intact, changes audio), I use rebox.NET, takes under 30 seconds as your not encoding the video.
If it's a full encode, I use MediaCoder, speed is dependent on your cpu and graphics card.
Console using
ServiiDroid for Android,
ServiiMetro and
ServiiWP for Windows Phone and
WebUI for iOS
