to turn off Serviio using the remote control for a TV
vasmixser
Post Tue Aug 19, 2014 3:00 pm
Hi
How to turn off Serviio using the remote control for a TV or via the TV menu...
Lowlander
Post Wed Aug 27, 2014 1:55 pm
Re: to turn off Serviio using the remote control for a TV
As far as a TV is concerned, it's only a DLNA renderer, and I don't think DLNA specifications cover DLNA devices powering down each other. And: If you turn sth off, you should be able to turn it back on again later.
If the device you run Serviio on (e.g. HTPC) is remote controllable, you might be able to stop and start the Serviio server process with a suitable remote control and a script.
Could you please explain a bit more what you are trying to achieve?
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
