Streaming from PC to TV
bazzle
Post Thu Sep 04, 2014 1:04 am
I currently can see Serviio from all the att equipment in my home network and different HiFi/tv rooms.
It works great. Using Serviio I can play all I have from the OTHER end.
What I would like to do is use Serviio as the streaming device from my main PC .
ie. If I right click on a video I can see the "play to" command and then the connected equipment.
Unfortunately some files do not give the "play to" command. Ive been told it uses WMP to do the play to and WMP doesn't support all video formats.
Can I use Serviio at the main PC to select video files and "Play to " connected equipment whilst sitting at the PC?
Post Thu Sep 04, 2014 1:43 am
Re: Streaming from PC to TV
No, the server cannot push to the clients.
bazzle
Post Thu Sep 04, 2014 2:42 am
Ok. Thank you for the reply. Do you know if this will be available later? Even in the paid version maybe?
Return to General discussion
