xbox 360 issues?
keaza
Post Fri Sep 05, 2014 7:06 am
xbox 360 issues?
i have just started serviio and love it so far, im having a issue where when i try and play a video... it just doesnt play, there is 3 current videos in my libary they will not play and i dont understand why.
the machine that is hosting the videos is running gentoo i have compiled ffmpeg with nearly every use flag that i can so its not ffmpeg causing the issue i dont think, i have looked in the logs and when i try access the video not even a log comes up anymore in a ealier log i got this message
2014-09-05 06:27:04,447 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/srv/movies/movietitle/motivetile2] movietitle2.mp4). Message: Unknown video file type.
can anyone please help me try fix this issue?
Post Fri Sep 05, 2014 1:58 pm
Re: xbox 360 issues?
Could you provide information about this video file ? (see signature link : fmpeg -i and mediainfo result)
keaza
Post Fri Sep 05, 2014 6:06 pm
thats one ill post the rest
ffmpeg version 2.2.7 Copyright (c) 2000-2014 the FFmpeg developers
built on Sep 5 2014 07:59:51 with gcc 4.7.3 (Gentoo 4.7.3-r1 p1.4, pie-0.5.5)
configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandi r=/usr/share/man --enable-shared --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-li nux-gnu-g++ --ar=x86_64-pc-linux-gnu-ar --optflags='-O2 -pipe' --extra-cflags='- O2 -pipe' --extra-cxxflags='-O2 -pipe' --disable-static --enable-gpl --enable-po stproc --enable-avfilter --enable-avresample --disable-stripping --enable-nonfre e --enable-version3 --enable-nonfree --disable-indev=alsa --disable-outdev=alsa --enable-version3 --enable-nonfree --enable-bzlib --enable-runtime-cpudetect --d isable-debug --disable-doc --enable-gnutls --enable-hardcoded-tables --enable-ic onv --enable-network --enable-openssl --enable-ffplay --enable-vaapi --enable-vd pau --enable-zlib --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libmp3l ame --enable-libaacplus --enable-libfaac --disable-libtheora --disable-libtwolam e --enable-libwavpack --disable-libwebp --enable-libx264 --enable-libx265 --enab le-libxvid --enable-libcdio --disable-libiec61883 --enable-libdc1394 --enable-li bcaca --enable-openal --enable-opengl --disable-libv4l2 --disable-libpulse --ena ble-x11grab --enable-libflite --disable-frei0r --enable-fontconfig --enable-lads pa --enable-libass --enable-libfreetype --enable-libsoxr --enable-pthreads --ena ble-libopencore-amrwb --enable-libopencore-amrnb --enable-libfdk-aac --enable-li bopenjpeg --enable-libbluray --enable-libcelt --enable-libgme --disable-libgsm - -enable-libmodplug --enable-libopus --enable-libquvi --enable-librtmp --enable-l ibssh --disable-libschroedinger --enable-libspeex --disable-libvorbis --enable-l ibvpx --disable-libzvbi --disable-armv5te --disable-armv6 --disable-armv6t2 --di sable-neon --disable-vfp --disable-mips32r2 --disable-mipsdspr1 --disable-mipsds pr2 --disable-mipsfpu --disable-altivec --disable-amd3dnow --disable-amd3dnowext --disable-sse3 --disable-ssse3 --disable-sse4 --disable-sse42 --enable-pic
libavutil 52. 66.100 / 52. 66.100
libavcodec 55. 52.102 / 55. 52.102
libavformat 55. 33.100 / 55. 33.100
libavdevice 55. 10.100 / 55. 10.100
libavfilter 4. 2.100 / 4. 2.100
libavresample 1. 2. 0 / 1. 2. 0
libswscale 2. 5.102 / 2. 5.102
libswresample 0. 18.100 / 0. 18.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Resident.Evil.2002.1080p.BluRay.H264.AA C-RARBG.mp4':
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
title : RARBG.COM - Resident.Evil.2002.1080p.BluRay.H264.AAC-RARBG
encoder : Lavf55.37.102
comment : RARBG.COM - Resident.Evil.2002.1080p.BluRay.H264.AAC-RARBG
Duration: 01:40:31.07, start: 0.000000, bitrate: 2729 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1040 [SAR 1:1 DAR 24:13], 2499 kb/s, 23.98 fps, 23.98 tbr, 11988 tbn, 47.95 tbc (def ault)
handler_name : VideoHandler
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 223 k b/s (default)
handler_name : SoundHandler
Conversion failed!
configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --enable-shared --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-linux-gnu-g++ --ar=x86_64-pc-linux-gnu-ar --optflags='-O2 -pipe' --extra-cflags='-O2 -pipe' --extra-cxxflags='-O2 -pipe' --disable-static --enable-gpl --enable-postproc --enable-avfilter --enable-avresample --disable-stripping --enable-nonfree --enable-version3 --enable-nonfree --disable-indev=alsa --disable-outdev=alsa --enable-version3 --enable-nonfree --enable-bzlib --enable-runtime-cpudetect --disable-debug --disable-doc --enable-gnutls --enable-hardcoded-tables --enable-iconv --enable-network --enable-openssl --enable-ffplay --enable-vaapi --enable-vdpau --enable-zlib --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libmp3lame --enable-libaacplus --enable-libfaac --disable-libtheora --disable-libtwolame --enable-libwavpack --disable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libcdio --disable-libiec61883 --enable-libdc1394 --enable-libcaca --enable-openal --enable-opengl --disable-libv4l2 --disable-libpulse --enable-x11grab --enable-libflite --disable-frei0r --enable-fontconfig --enable-ladspa --enable-libass --enable-libfreetype --enable-libsoxr --enable-pthreads --enable-libopencore-amrwb --enable-libopencore-amrnb --enable-libfdk-aac --enable-libopenjpeg --enable-libbluray --enable-libcelt --enable-libgme --disable-libgsm --enable-libmodplug --enable-libopus --enable-libquvi --enable-librtmp --enable-libssh --disable-libschroedinger --enable-libspeex --disable-libvorbis --enable-libvpx --disable-libzvbi --disable-armv5te --disable-armv6 --disable-armv6t2 --disable-neon --disable-vfp --disable-mips32r2 --disable-mipsdspr1 --disable-mipsdspr2 --disable-mipsfpu --disable-altivec --disable-amd3dnow --disable-amd3dnowext --disable-sse3 --disable-ssse3 --disable-sse4 --disable-sse42 --enable-pic
File '28.Days.Later.2002.1080p.BluRay.H264.AAC-RARBG.mp4' already exists. Overwrite ? [y/N]
Not overwriting - exiting
Conversion failed!
two mp4 files that do not work, they play on every other device, bar the xbox
keaza
Post Mon Sep 08, 2014 3:15 am
Anyone please?
