repeter
ahh1
Post Mon Sep 08, 2014 8:10 pm
repeter
I need to connect a TV at my second house about 50 meters away but I can't connect with cable and the onle way is with WiFi repeater. I connect will the TV with the repeater and the repeater through WiFi with my router and the router with pc . Will the TV see the file I have enter at serviio library?
Post Mon Sep 08, 2014 9:27 pm
Re: repeter
ahh1 wrote:I need to connect a TV at my second house about 50 meters away but I can't connect with cable and the onle way is with WiFi repeater. I connect will the TV with the repeater and the repeater through WiFi with my router and the router with pc . Will the TV see the file I have enter at serviio library?
If it's operating in bridge mode, then yes you should be able to see it across the WiFi. If you are only streaming SD video, there should not be a bandwidth issue. More bandwidth is better, though! :D
However, it your repeater acts as a router, and assigns new IP addresses for the remote side, it becomes more problematic. I believe most repeaters act as a bridge, but you'll want to be sure.
