Sony Bravia 2010 and subtitles
hreintke
Post Sat Aug 02, 2014 2:08 pm
LS,
I cannot get burned subtitles to work on my Sony Bravia 2010 model.
Situation :
Serviio 1.4.1.2 on Synology NAS.
In directory : MM821.avi and MM821.srt
I saved the MM821 in UTF-8 encoding.
I have all three checkboxes on subtitle page checked, (enable burned in = always).
When starting the video I shortly see the text subtitles appear in the output video.
But no actual subtitles appear.
I set debug mode and (my interpretation ?)
- Seviio sees the srt
- I do not see the subtitle(file) in the ffmpeg command.
Anything that I need to set additional ?
Kind regards
Herman
2014-08-02 15:42:48,503 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 119)
2014-08-02 15:42:48,504 DEBUG [VideoDAOImpl] Reading a Video (id = 119)
2014-08-02 15:42:48,505 DEBUG [VideoDeliveryEngine] Delivering item '119' for client 'Identifier=10.0.0.210, Profile=Sony Bravia TV (2010)'
2014-08-02 15:42:48,506 DEBUG [VideoDeliveryEngine] Delivering file 'MM821.avi' using transcoding
2014-08-02 15:42:48,506 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-118-sony2010-ORIGINAL.stf', will stop the job
2014-08-02 15:42:48,506 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-118-sony2010-ORIGINAL.stf'
2014-08-02 15:42:48,506 DEBUG [TranscodingJobListener] Deleted temp file '/volume1/@tmp/Serviio/transcoding-temp-118-sony2010-ORIGINAL.stf': false
2014-08-02 15:42:48,506 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=10.0.0.210, Profile=Sony Bravia TV (2010)'
2014-08-02 15:42:48,507 DEBUG [MediaItemDAOImpl] Getting file of media item 119
2014-08-02 15:42:48,509 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /volume1/video/Midsomer Murders 8/MM821.avi
2014-08-02 15:42:48,509 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -threads 2 -i /volume1/video/Midsomer Murders 8/MM821.avi -y -threads 2 -c:v mpeg2video -pix_fmt yuv420p -b:v 17000k -maxrate:v 17000k -bufsize:v 17000k -vf pad=598:336:43:0:black,setdar=4:3 -r 25 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /volume1/@tmp/Serviio/transcoding-temp-119-sony2010-ORIGINAL.stf
2014-08-02 15:42:50,010 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-08-02 15:42:50,011 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MM821.avi: MPEG_TS_SD_EU_ISO
2014-08-02 15:42:50,011 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MM821.avi: MPEG_TS_SD_NA_ISO
2014-08-02 15:42:50,011 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MM821.avi: MPEG_TS_SD_KO_ISO
2014-
2014-08-02 15:42:40,860 DEBUG [VideoDAOImpl] Reading a Video (id = 119)
2014-08-02 15:42:40,861 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 119 and profile Sony Bravia TV (2010)
2014-08-02 15:42:40,861 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MM821.avi: MPEG_TS_SD_EU_ISO
2014-08-02 15:42:40,862 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MM821.avi: MPEG_TS_SD_NA_ISO
2014-08-02 15:42:40,862 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MM821.avi: MPEG_TS_SD_KO_ISO
2014-08-02 15:42:40,862 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 151)
2014-08-02 15:42:40,864 DEBUG [MediaItemDAOImpl] Getting file of media item 119
2014-08-02 15:42:40,865 DEBUG [SubtitlesService] Found external subtitles file: MM821.srt
2014-08-02 15:42:40,865 DEBUG [ResourceValuesBuilder] Softsubs for media item 119 found, will be served as a resource
Xmantium
Post Mon Aug 25, 2014 5:47 pm
Re: Sony Bravia 2010 and subtitles
I got subtitles working on my Sony 2010 TV, was tricky using on my QNAP NAS as you have to copy the font files to make subtitles work
Try is on Windows to make sure it works, im sure it will, maybe something in your install thats causing the fault
patters
Post Tue Sep 09, 2014 6:49 am
The Synology package installs a free font and the configuration files. Try several different media files with subs to eliminate the possibility of a non-compliant srt file. Also read these tips:
http://www.serviio.org/index.php?option ... icle&id=33
...particularly try using Srtwiz.
Users browsing this forum: Baidu [Spider] and 30 guests
