Samsung BD C6900 don't find PC
krille30
Post Sun Feb 13, 2011 11:37 am
Hi!
I have problem connecting my PC to Samsung BD C6900. The problem is that Samsung BD C6900 don't show my PC, serviio show the ip number and find samsung but something strange is that all devices has yellow dot. What could be the reason of this? Just notice is that sometimes the samsung find PC, but most of the time I can't see my device in the blueray.
My network is one PC and one laptop, both connected wireless to router and samsung BD C6900 connected with cabel to the router. Serviio is only installed on the PC. Sorry about swedish language in attachment.
Post Sun Feb 13, 2011 1:11 pm
Re: Samsung BD C6900 don't find PC
Is 192.168.2.2 the IP of the PC? Make sure the PC (and Bluray) have static IP addresses setup on your router so that it stays the same.
Orange dot is ok, just means that the status of the player cannot be retrieved (on/off) as it doesn't support this functionality.
krille30
Post Sun Feb 13, 2011 2:15 pm
Thanks for the quick respons zip. That correct PC is 192.168.2.2, Laptop is 192.168.2.3 and Blueray is 192.168.2.6, all are added as static ip adresses in router from there Mac Adresses. And still problem with finding pc in bluray.
Post Sun Feb 13, 2011 3:23 pm
Post the log, make sure there is no firewall on the PC (or open port 8895)
krille30
Post Sun Feb 13, 2011 3:50 pm
ok, have checked that windows firewall i accepting serviio. Here is the logfile. I had to zip the file because it would be to large to upload otherwise hope that works for you. Thanks in advance. Just to be clear I have changed the IP for the bluray to 192.168.2.5, because I wanted to test if it was something wrong with the ip adress. So you will probably see that IP adress in the logfile. The ipadress for the PC should be same as before.
serviio.zip
(166.64 KiB) Downloaded 856 times
Post Sun Feb 13, 2011 4:04 pm
there are only incoming requests from 192.168.2.2 which is the PC itself. Are you sure you don't have any other firewall installed? eg antivirus with firewall
krille30
Post Sun Feb 13, 2011 4:18 pm
I tried to inactivate both my antivirus and firewall with no sucess. The strange thing is that when I have my bluray on and just start my computer the computer normal is found in the bluray. Then when I close the bluray and put it on again the computer is normaly gone. So it seem to be sometimes that I can connect and sometimes I don't.
Post Sun Feb 13, 2011 5:57 pm
The Search from the player never gets delivered (may be lost as it's UDP traffic). Clicking on Stop/Start server in the console should fix it right?
Users browsing this forum: Google [Bot] and 20 guests
