Windows 8.1 64-bit support?
Thanks in advance...TomP
TomP wrote:Thanks. I see there are 'Static' and 'Shared' versions of 64-bit FFMPEG, so which one do I need - and why do I need FFMPEG at all? I use MakeMKV and HandBrake to do all my ripping / conversion already.
Best Regards...TomP
atc98092 wrote:TomP wrote:Thanks. I see there are 'Static' and 'Shared' versions of 64-bit FFMPEG, so which one do I need - and why do I need FFMPEG at all? I use MakeMKV and HandBrake to do all my ripping / conversion already.
Best Regards...TomP
As Zip says, use the static version. As to why it's there, if your files can all be played without transcoding, it will never fire up. It is there to transcode files as necessary.
As an example, my Sony players can handle virtually everything without transcoding, so FFMPEG never runs and my CPU is loafing. However, my Roku needs everything except MP4 video transcoded. Even though it can play MKV files, it can't play MPEG2 video. It also can't handle HD video without throttling the stream back. So FFMPEG converts my videos to M2TS with AC3 sound and a bitstream no higher than 12,000Kbps.
