Sony BDP-S3200 ... works fine, craps out if you back out
flipty
Post Mon Sep 22, 2014 12:10 am
Just like it sounds. If I reboot the Blu Ray player it will come up and work great. However if you go "Back" with the remote to the BDP's home screen you immediately get a message overlay saying that the server Data cannot be read or something along those lines.
UPDATE (before I even posted the original message...) I've solved the problem (thus far) by assigning the proper DNLA profile and restarting the server. I'll revisit this thread if the problem persists. Love Serviio!
ekanson
Post Tue Mar 24, 2015 12:21 am
Re: Sony BDP-S3200 ... works fine, craps out if you back out
Hi. I am having the same problem with my BDP-S3200. Could you pls share how you fixed it? Thanks
