MKV Plays Corrupted (Green Screen, Digital Noise, etc.)
Timmy1024
Post Sat Sep 13, 2014 12:50 am
Hi there,
I'm about to get me a license to use Serviio with my newly adquired Samsung 55' F8000 (UN55F8000) because I've found that Serviio plays most of the files in it.
However, I've stumbled upon a Depeche Mode Concert (MKV) that plays corrupted. It starts playing on the client, but forwards randomly, with digital noise, green screens, freezes, etc.
This is the ffmpeg -i output:
Input #0, matroska,webm, from 'Depeche Mode Tour of the Universe - Live in Barce
lona 1080p DTS.mkv':
    encoder         : libebml v0.7.9 + libmatroska v0.8.1
    creation_time   : 2010-11-15 21:32:04
  Duration: 02:01:13.30, start: 0.000000, bitrate: 5247 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709), 1920x840 [SAR 1:1
DAR 16:7], 29.76 fps, 29.76 tbr, 1k tbn, 180k tbc (default)
      title           : Depeche Mode Tour of the Universe - Live in Barcelona 10
80p DTS [mkvonly]
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 768 kb/s (def
ault)
And this is the MediaInfo output:
Unique ID                                : 208862504695689719024571091038203539724 (0x9D21748855E43DAA9BC4FA9C2047F10C)
Complete name                            : Depeche Mode Tour of the Universe - Live in Barcelona 1080p DTS [mkvonly]\Depeche Mode Tour of the Universe - Live in Barcelona 1080p DTS.mkv
File size                                : 4.44 GiB
Duration                                 : 2h 1mn
Overall bit rate                         : 5 248 Kbps
Encoded date                             : UTC 2010-11-15 21:32:04
Writing application                      : mkvmerge v3.1.0 ('Happy up here') built on Jan 19 2010 12:09:24
Writing library                          : libebml v0.7.9 + libmatroska v0.8.1
Format profile                           : High@L4.0
Duration                                 : 2h 1mn
Bit rate                                 : 4 500 Kbps
Height                                   : 840 pixels
Display aspect ratio                     : 2.25:1
Frame rate                               : 29.970 fps
Bits/(Pixel*Frame)                       : 0.093
Stream size                              : 3.72 GiB (84%)
Title                                    : Depeche Mode Tour of the Universe - Live in Barcelona 1080p DTS [mkvonly]
Writing library                          : x264 core 88
Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=4500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 2h 1mn
Bit rate                                 : 755 Kbps
Bit depth                                : 24 bits
Stream size                              : 654 MiB (14%)
Here are a couple of screen captures:
After a while, it crashes:
Would you know what the problem might be?
EDIT: by the way, sound also skips and make weird noises
probedb
Post Wed Sep 17, 2014 8:22 am
Re: MKV Plays Corrupted (Green Screen, Digital Noise, etc.)
Does the MKV play from a USB stick?
Timmy1024
Post Wed Sep 17, 2014 7:41 pm
Thanks probe! Nice question! :)
I just tried and it does the same while playing from a USB stick; the same error appears. The corruption doesn't show on players such as VLC on the computer or Showtime in the PS3.
Any ideas on how I could fix the file or what might the problem be?
Post Mon Sep 22, 2014 12:13 pm
So normally Samsung doesn't need transcoding, so the file is delivered natively. It's then up to the TV to decode it, which in this case apparently fails. You could reencode it using one of the many encoding tools, to mp4 or mkv again.
probedb
Post Tue Sep 23, 2014 11:58 am
It's also possible that the profile for h264 is just too high, I think mkvmerge will allow you to reduce the profile, I certainly remember doing something similar with files on my PS3 years ago.
Timmy1024 wrote:Thanks probe! Nice question! :)
Users browsing this forum: Baidu [Spider], Google [Bot] and 27 guests
