dxva fffmpeg usage
hennys
Post Fri Feb 11, 2011 7:07 pm
dxva fffmpeg usage
I saw on the web a ffmpeg version built for a program called ipimp that contains dxva (gpu usage).
http://code.google.com/p/ipimp/download ... p&can=2&q=
Is it possible to use/reuse/adjust this version of ffmpeg with serviio, so serviio can benefit from gpu power ?
Kind regards,
Hen
Post Sat Feb 12, 2011 11:28 am
Re: dxva fffmpeg usage
I assume they compiled it with a patch. If someone can find it then it should be no problem (as long as it won't break and work on all OSes)
hennys
Post Sat Feb 12, 2011 9:04 pm
zip wrote:I assume they compiled it with a patch. If someone can find it then it should be no problem (as long as it won't break and work on all OSes)
Hi zip,
dxva is a windows technology, so all platforms will be out of the question.
I have done some test with this and either I don't know the correct command line, or it is not encoding any faster than CPU based.
Regards,
Hen
hennys
Post Sun Feb 13, 2011 4:20 pm
With ony one thread the transcoding with GPU was about 25% faster. With more cpu cores the difference fades.
Kind regards,
Hen
Post Sun Feb 13, 2011 5:39 pm
Thanks for the info
