Serviio won't start on Mac Mini running 10.9.4
eobet
Post Tue Sep 02, 2014 10:00 pm
The dock icon bounces for several minutes, and then stops, but no light beneath it turns on, and right clicking on it says the application has stopped responding, with force quit being the only option.
What could be the problem?
Post Wed Sep 03, 2014 4:17 pm
Re: Serviio won't start on Mac Mini running 10.9.4
It's probably running, you can check the server's status in Serviio Console.
blabla
Post Thu Sep 04, 2014 7:28 pm
I have the same problem. I have a Macbook Pro which is running Mac OS 10.9.4. Serviio was running fine a few days ago on Mountain Lion (I have been using it for a few months now) but it stopped working after upgrading to Mavericks. The icon bounces constantly and doesn't do anything. Before it would bounce up and down once or twice and then disappear entirely. The console also says that the server isn't running.
Post Mon Sep 22, 2014 12:15 pm
I'm working on a different model for OSX for 1.5, so hopefully all these problems will go away.
