Serviio doesnt start after updating packages on Ubuntu 14.04
nmt
Post Mon Sep 22, 2014 8:47 pm
Hi.
First of all, props to the developers for writing a good & stable app. I enjoy using it most of the time.
I just applied some updates to Ubuntu 14.04 and now Serviio doesn't want to start anymore. Doesn't say why.
I can attach any file if you tell me what you need. Thank you!
nmt
Post Tue Sep 23, 2014 6:16 am
Re: Serviio doesnt start after updating packages on Ubuntu 1
I think the problem is related to the new java version I just upgrated to (java version "1.7.0_65").
Serviio stops after a few seconds and this is the last log entry:
2014-09-23 09:14:16,766 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
   at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:59)
   at org.serviio.MediaServer.main(MediaServer.java:116)
Help please!
Post Tue Sep 23, 2014 11:48 am
does the same happen with a clean install? It looks like it cannot connect to the database.
nmt
Post Tue Sep 23, 2014 2:14 pm
Thanks. I deleted the old files and copied them once again and it works now. Can you please tell me which files to back up in the future so that my settings & licence details won't be lost?
Post Tue Sep 23, 2014 11:02 pm
normally it'd be the library folder, but it might be the one you had a problem with
Users browsing this forum: Baidu [Spider], Google [Bot] and 27 guests
