Lip sync problems using Samsung
scottvan1
Post Fri Aug 08, 2014 11:50 pm
I have a Samsung TV - 60F5500AF plasma, A Samsung BR - BD-F5900 and I am using serviio 1.4.1.2. The sound is not in sync on some files. - .mkv mainly. I can send logs - please tell me which ones and where?
thanks, Scott
scottvan1
Post Tue Sep 23, 2014 1:45 pm
Re: Lip sync problems using Samsung
Does anyone have a suggestion as to what to try for my issue? I have a variable problem, sometime not at all and some times quite a bit off on the sound. I have removed all processing on the TV to try to eliminate the problem but that didn't work. Any help is appreciated
scottvan1
Post Fri Sep 26, 2014 4:09 am
Does anyone know of a another media server software i can use? I cannot get my questions answered or issue resolved here.
Post Sun Sep 28, 2014 5:55 pm
The files are not transcoded, so it's up to either the TV or the network. it could also be the file being dodgy. Alternativley, if you're using AV receiver, you can set the audio / video delay if you're getting if for all files.
Users browsing this forum: Google [Bot] and 42 guests
