How to transcode 5.1 AAC to AC3?
Hogar
Post Sat Sep 27, 2014 10:55 pm
I've been searching forums but I can't find the working code (profile) for this.
So I'm using Serviio to stream video files to WD TV Live. BUT the audio is being played through older generation Sony STR-DB930QS AV 5.1 Receiver, which doesn't support decoding AAC stream (and has no HDMI connectors). So I need to transcode AAC audio stream into "standard" Dolby Digital AC3 audio stream (or DTS, whatever is doable).
HELP!
I've tried the solution from this link but it didn't work - I added this line
<Matches container="matroska" vCodec="h264" aCodec="aac" />
BUT after adding it, some of the video files stopped working! WD TV Live started reporting "filetype not supported" - I think that happened with all the files that use H.264 video encoding.
Currently my profile looks like this:
   <Profile id="14" name="WDTV Live" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <ModelName>WD TV HD Live</ModelName>
         </UPnPSearch>
      </Detection>
            <Matches container="wtv" />
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="flv" /> <!-- this is used by online content, assuming WDTV cannot play local flv either -->
            <Matches container="rm" />
<!-- transcode H264 MP4 files with LPCM audio -->
                <Matches container="mpegts" aCodec="mp2" />
                <Matches container="mp4" aCodec="lpcm" />
                <Matches container="matroska" vCodec="vc1" />
                <Matches container="ogg" vCodec="mpeg4" />
                <Matches container="3gp" aCodec="amrnb" />
         <OnlineTranscoding>
            <Matches container="mp4" />
            <Matches container="asf" /> <!-- for mms:// -->
      </OnlineTranscoding>
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
      </Subtitles>
Serviio: 1.4.1.2
WD TV Live: WDBAAP0000NBK-01 (first generation)
Connected via optical audio cable to Sony STR-DB930QS AV 5.1 Reciever (supports Dolby Digital and DTS, but not AAC, mp3 and other "modern" codecs).
THANK YOU!!
Post Mon Sep 29, 2014 9:21 am
Re: How to transcode 5.1 AAC to AC3?
Where did you add your line?
Put it above the line:
Also, you may want to add a similar line for the MP4 case. If that doesn't work try changing the line:
    to
If still no good, have a look at the transcoded file and post MediaInfo details for it. Remember to restart the Serviio service (or your PC) after changing profiles.
