MKV audio and video stutter, fix or remux?
I'm using the Panasonic 2010 profile on my TX-P50G20BA (latest version of Serviio and high spec PC, connected through homeplugs) and pretty much everything plays including most mkv's without any issues. An example I am having trouble with is detailed below (aspect ratio correct with black bars above and below):
- Code:
Unique ID : 176121867618419934911797495194306499691 (0x847FD67EB2EBD9E6B1BD8DE9A254546B)
Complete name : F:\Media\Film\Transformers Age of Extinction.mkv
Format : Matroska
File size : 6.56 GiB
Duration : 2h 45mn
Overall bit rate : 5 684 Kbps
Encoded date : UTC 2014-09-18 20:51:00
Writing application : mkvmerge v7.1.0 ('Good Love') 64bit built on Jul 27 2014 13:06:55
Writing library : libebml v1.3.0 + libmatroska v1.4.1
DURATION : 02:35:41.832000000
NUMBER_OF_FRAMES : 2509
NUMBER_OF_BYTES : 80548
_STATISTICS_WRITING_APP : mkvmerge v7.1.0 ('Good Love') 64bit built on Jul 27 2014 13:06:55
_STATISTICS_WRITING_DATE_UTC : 2014-09-18 20:51:00
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 45mn
Bit rate : 5 043 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.307
Stream size : 5.69 GiB (87%)
Writing library : x264 core 142 r2479 dd79a61
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=5043 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
DURATION : 02:45:07.273000000
NUMBER_OF_FRAMES : 237537
NUMBER_OF_BYTES : 6243731577
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 45mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 756 MiB (11%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English FORCED
Language : English
Default : Yes
Forced : Yes
Text #2
Format : UTF-8
Title : English
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Title : English SDH
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:06:51.578 : en:00:06:51.578
00:14:33.581 : en:00:14:33.581
00:21:37.463 : en:00:21:37.463
00:30:13.395 : en:00:30:13.395
00:38:45.990 : en:00:38:45.990
00:46:08.057 : en:00:46:08.057
00:51:39.513 : en:00:51:39.513
00:59:09.337 : en:00:59:09.337
01:07:48.648 : en:01:07:48.648
01:15:14.552 : en:01:15:14.552
01:23:25.292 : en:01:23:25.292
01:29:14.724 : en:01:29:14.724
01:37:16.956 : en:01:37:16.956
01:44:35.436 : en:01:44:35.436
01:51:25.053 : en:01:51:25.053
01:57:47.936 : en:01:57:47.936
02:04:48.481 : en:02:04:48.481
02:12:35.865 : en:02:12:35.865
02:21:04.206 : en:02:21:04.206
02:28:48.670 : en:02:28:48.670
02:37:09.629 : en:02:37:09.629
Now, there is either something totally obvious in the above to everyone apart from me and there is a simple solution.....or I could remux (as I have done with PS3Muxer) into an mp4 where the stuttering disappears, however the aspect ratio gets screwed (stretched vertically) when I do this. The resulting mp4 is larger than the original, however, I have not noticed a reduction in the quality of the video (details of the mp4 below) and the bitrates are the same for both files.
- Code:
Complete name : F:\Media\Film\Transformers Age of Extinction.mp4
Format : MPEG-TS
File size : 6.82 GiB
Duration : 2h 45mn
Overall bit rate : 5 913 Kbps
Maximum Overall bit rate : 35.5 Mbps
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 2h 45mn
Bit rate mode : Variable
Maximum bit rate : 40.0 Mbps
Height : 536 pixels
Color space : YUV
Bit depth : 8 bits
Stream size : 5.74 GiB (84%)
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 2h 45mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Therefore my questions are as follows:
1. Is there anything in the above which I should beware of in mkv's?
2. If yes, can it be fixed to prevent stuttering? I assume by the posts I have read there is no clear solution and that remuxing might be the best way forward.
3. If remuxing, is there a way I can force the aspect ratio (in the Panasonic 2010 profile) to stay the same as in the original mkv when playing an mp4 (remuxed mkv with PS3Muxer) ?
4. If remuxing is the only answer, what is the best tool for it?
Much appreciated
