Audio transcoding downmix to stereo - LFE channel?
donarkaz
Post Tue Sep 30, 2014 5:06 pm
I would like to ask whether the Downmix to stereo audio option actually DOES include the LFE channel in the stereo downmix, so the Left and Right channels both have the LFE audio channel blend in...
If not, will it be in scope for a next release, or do you know of any other DLNA server software that provides this very functionality please?
Thank you in advance.
probedb
Post Fri Oct 03, 2014 9:11 am
Re: Audio transcoding downmix to stereo - LFE channel?
Even in a 5.1 setup the LFE is a separate channel, if you have no sub you don't get the LFE, it isn't mixed into the rest of the mix as far as I'm aware. I'd assume the same for stereo downmix.
Post Sat Oct 04, 2014 11:30 am
I'm not sure if FFmpeg supportes it. You can check the ffmpeg command that is used and ask at the ffmpeg forum / mailing list.
Users browsing this forum: Baidu [Spider] and 38 guests
