MKV won't play on PS3, if I FFMPEG it to MP4 plays fine
waterlooalex
Post Fri Oct 03, 2014 11:25 pm
I've got a MKV file that won't play on my PS3 from Serviio, but, if I change its container then it plays fine:
ffmpeg -y -i fargo.s01e02.720p.hdtv.x264-killers.mkv -c copy fargo2.mp4
Is it possible to get serviio to do this for me?
Here is MEDIA INFO for the file:
Unique ID                                : 121173099302006606500006621113520925755 (0x5B29170CDC6EACC9F5D6827A437EAC3B)
Complete name                            : \\nas\videos\fargo.s01e02.720p.hdtv.x264-killers.mkv
Format version                           : Version 4 / Version 2
File size                                : 2.24 GiB
Duration                                 : 48mn 46s
Overall bit rate                         : 6 588 Kbps
Encoded date                             : UTC 2014-04-23 03:11:37
Writing application                      : mkvmerge v6.0.0 ('Coming Up For Air') built on Jan 20 2013 10:28:01
Writing library                          : libebml v1.3.0 + libmatroska v1.4.0
Format settings, ReFrames                : 5 frames
Duration                                 : 48mn 46s
Bit rate                                 : 6 073 Kbps
Bits/(Pixel*Frame)                       : 0.275
Stream size                              : 2.07 GiB (92%)
Writing library                          : x264 core 142 r2409 d6b4e63
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 48mn 46s
Bit rate                                 : 384 Kbps
Stream size                              : 134 MiB (6%)
Post Mon Oct 06, 2014 11:17 am
Re: MKV won't play on PS3, if I FFMPEG it to MP4 plays fine
This should happen by default if you have the Playstation 3 profile selected, and transcoding is enabled. Check these settings (in Serviio console - renderer profile in the Status tab, and
enable Transcoding on the Delivery tab.
waterlooalex
Post Mon Oct 06, 2014 3:50 pm
DenyAll wrote:This should happen by default if you have the Playstation 3 profile selected, and transcoding is enabled. Check these settings (in Serviio console - renderer profile in the Status tab, and
The Playstation 3 profile is selected. Transcoding is enabled. I think thats how/why the first MKV file plays.
Post Tue Oct 07, 2014 11:49 am
Not sure - if its still a concern then perhaps check the Serviio detailed log to see what is failing.
waterlooalex
Post Tue Oct 07, 2014 3:23 pm
Its still a concern, nothing has changed.
Its the same issue we're discussing on the other thread, and I included a snippet of the Serviio log there: viewtopic.php?f=11&t=17682&p=94797#p94797
DenyAll wrote:Not sure - if its still a concern then perhaps check the Serviio detailed log to see what is failing.
