java is hungry with my ram!!
thenamelessthing
Post Sun Oct 05, 2014 2:37 am
Hi all, I just reinstall my ubuntu server with 14.04 and I have noticed an issue with serviio. (in fact is java) On certain video java use almost all my ram! more than 5gb of ram with no transcoding! it is normal? The video hang etc... with some other video everything are okay.
Any advice for this behavior?
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
thenamelessthing
Post Mon Oct 06, 2014 5:01 pm
Re: java is hungry with my ram!!
Here additionnal info:
java process of serviio:
memory mapping of this process:
At the moment of taking these screenshot, the server was on idle....!
Post Sun Oct 12, 2014 10:27 pm
thenamelessthing
Post Tue Oct 14, 2014 12:49 am
So
You mean I have enough ram?
Why some video lag and other not? They have the same quality!
Post Fri Oct 17, 2014 5:22 pm
Could be realted to:
- network lag
- transcoding performance
- encoding of the video (bitrate, other video characteristics)
