sony BDV-E870 home cinema system *missing subtitles*
freaky85
Post Sun Feb 13, 2011 6:09 pm
Hi all
I'll hope you can help me with my problem
i got no subtitles showing no matter wich profile i use.
i guess i schould use sony bd player (EU) but my unit cant seem to stream them with my divx movies
what schould i do?
ps i have named them both srt + avi identical names
Post Sun Feb 13, 2011 6:15 pm
Re: sony BDV-E870 home cinema system *missing subtitles*
freaky85
Post Sun Feb 13, 2011 6:17 pm
i guess i cant get it to work then?
is that correct understood!!
Post Sun Feb 13, 2011 6:24 pm
Illico wrote:FAQ
Things to know
- Make sure you are browsing the proper section of the Sony XMB (press Home then left several times).
The Serviio audio, image and video folders will all show up in each category due to how DLNA servers work - it's just the Sony that insists on having a menu for each category.
- MKV "Data corrupted" potential solution : viewtopic.php?f=6&t=1132
- AVC H264 High Profile maximum Level is 4.1 (use TsMuxer to change level)
Supported
- Thumbnail artwork only support for photos media using JPEG_TN resource.
- Subtitle and Multi Audio Tracks are supported from MKV files over DLNA (European model)
Not Supported
- Thumbnail artwork for video or audio media are not supported.
- Subtitle not supported in MPEG program streams (VOB files in other words). The player supports these from disc, but not via DLNA
- SRT subtitle files not supported
freaky85
Post Sun Feb 13, 2011 7:23 pm
howcome is this coded in the profile then if it's not supported
<!-- set mkv to divx mime-type to allow subtitle and multiple audio track support -->
Post Mon Feb 14, 2011 8:36 am
Illico wrote:FAQ
Things to know
Supported
Not Supported
Subtitles are only supported when embedded/remuxed with video an audio in mkv (container), external SRT subtitle files are not supported.
