"Cannot connect to Serviio server"
gasfarmer
Post Sun Oct 12, 2014 11:47 pm
I've been Googling around, and I can't find the answer to this. Everyone whose found a solution apparently doesn't have the time to share it online.
Every single time I try to start Serviio, it says "Cannot connect to Serviio server, it does not seem to be running, Exiting."
I've read the wiki, and found no answers. At least not ones that didn't fly a million feet over my head.
How do I fix this? Plain and simple.
Post Fri Oct 17, 2014 5:52 pm
Re: "Cannot connect to Serviio server"
Probably the Console starts before the server manages to start-up.
Easiest solution is to remove the console from the Start menu's Startup folder, so that the console doesn't start automatically. You don't need it for streaming and you can always start it manually.
