Passthrough DTS?
Encrypted
Post Mon Feb 14, 2011 2:51 am
Passthrough DTS?
Is there a way to passthrough DTS? I was trying to figure it out but there doesn't seem to be a way to output int dts?
Post Mon Feb 14, 2011 8:32 am
Re: Passthrough DTS?
Please need details:
- DLNA rendere model
- Serviio profile used
- Video source file used "ffmpeg -i"
- etc.
Encrypted
Post Mon Feb 14, 2011 3:24 pm
I havn't been using serviio long so bare with me.
I am using a PS3 with a tweaked profile to allow me to transcode multichannel aac into ac3 as my receiver doesn't support it.
Added line:
<Matches container="mp4" aCodec="aac" />
Not sure about the video source file used.
Post Mon Feb 14, 2011 8:03 pm
Encrypted wrote:...I am using a PS3 with a tweaked profile to allow me to transcode multichannel aac into ac3 as my receiver doesn't support it.
OK so it looks like this ?
   <Profile id="4" name="Playstation 3" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <X-AV-Client-Info>.*PLAYSTATION 3.*</X-AV-Client-Info>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
      </MediaFormatProfiles>
Encrypted wrote:Not sure about the video source file used.
Please select a file on your library with DTS audio and provide "ffmpeg -i <file>" result.
Encrypted
Post Mon Feb 14, 2011 10:38 pm
Yes, it looks like that. I will provide you the output from that command when I get home from work. Thanks. I do have a number of files with DTS encoding which I have been able to get to play as DTS with PS3 Media Server.
Encrypted
Post Tue Feb 15, 2011 4:16 am
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 012ebbc0] max_analyze_duration reached
[matroska,webm @ 012ebbc0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from 'C:\Users\Dave\Desktop\Movies\Avatar 2009 1080p Bl
uRay X264-AMIABLE\avatar.2009.1080p.bluray.x264.mkv':
Duration: 02:41:41.65, start: 0.000000, bitrate: 1536 kb/s
Chapter #0.0: start 0.000000, end 377.961000
title : 00:00:00.000
Chapter #0.1: start 377.961000, end 473.598000
title : 00:06:17.961
Chapter #0.2: start 473.598000, end 724.891000
title : 00:07:53.598
Chapter #0.3: start 724.891000, end 840.465000
title : 00:12:04.891
Chapter #0.4: start 840.465000, end 1200.574000
title : 00:14:00.465
Chapter #0.5: start 1200.574000, end 1440.230000
title : 00:20:00.574
Chapter #0.6: start 1440.230000, end 1613.278000
title : 00:24:00.230
Chapter #0.7: start 1613.278000, end 1901.900000
title : 00:26:53.278
Chapter #0.8: start 1901.900000, end 2013.428000
title : 00:31:41.900
Chapter #0.9: start 2013.428000, end 2143.850000
title : 00:33:33.428
Chapter #0.10: start 2143.850000, end 2611.859000
title : 00:35:43.850
Chapter #0.11: start 2611.859000, end 2963.627000
title : 00:43:31.859
Chapter #0.12: start 2963.627000, end 3269.975000
title : 00:49:23.627
Chapter #0.13: start 3269.975000, end 3596.051000
title : 00:54:29.975
Chapter #0.14: start 3596.051000, end 3910.198000
title : 00:59:56.051
Chapter #0.15: start 3910.198000, end 4296.417000
title : 01:05:10.198
Chapter #0.16: start 4296.417000, end 4511.006000
title : 01:11:36.417
Chapter #0.17: start 4511.006000, end 4829.116000
title : 01:15:11.006
Chapter #0.18: start 4829.116000, end 5081.910000
title : 01:20:29.116
Chapter #0.19: start 5081.910000, end 5764.801000
title : 01:24:41.910
Chapter #0.20: start 5764.801000, end 5875.786000
title : 01:36:04.801
Chapter #0.21: start 5875.786000, end 6273.100000
title : 01:37:55.786
Chapter #0.22: start 6273.100000, end 6495.489000
title : 01:44:33.100
Chapter #0.23: start 6495.489000, end 6833.868000
title : 01:48:15.489
Chapter #0.24: start 6833.868000, end 6932.884000
title : 01:53:53.868
Chapter #0.25: start 6932.884000, end 7118.820000
title : 01:55:32.884
Chapter #0.26: start 7118.820000, end 7325.568000
title : 01:58:38.820
Chapter #0.27: start 7325.568000, end 7533.859000
title : 02:02:05.568
Chapter #0.28: start 7533.859000, end 7801.835000
title : 02:05:33.859
Chapter #0.29: start 7801.835000, end 8167.284000
title : 02:10:01.835
Chapter #0.30: start 8167.284000, end 8390.841000
title : 02:16:07.284
Chapter #0.31: start 8390.841000, end 8750.325000
title : 02:19:50.841
Chapter #0.32: start 8750.325000, end 9074.065000
title : 02:25:50.325
Chapter #0.33: start 9074.065000, end 9305.296000
title : 02:31:14.065
Chapter #0.34: start 9305.296000, end 9701.651000
title : 02:35:05.296
Stream #0.0(eng): Video: h264, yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 f
ps, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0.1(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
title : English DTS 1509kbps
Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000
title : English
Stream #0.3(eng): Subtitle: [0][0][0][0] / 0x0000
title : English
Post Tue Feb 15, 2011 9:34 am
Try this:
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
            <Matches container="matroska" vCodec="h264" aCodec="dca" />
Encrypted
Post Wed Feb 16, 2011 2:34 am
Didn't seem to work. I get no audio at all. The Ps3 shows no audio streams. I think I actually tried that before I posted and had the same results.
Post Wed Feb 16, 2011 8:17 am
Could you check and post the serviio detailed logging?
Encrypted
Post Sun Feb 20, 2011 12:46 am
How do I enable detailed logging? Is it just the log file you want me to post?
Is DTS supposed to be supported function?
Post Sun Feb 20, 2011 12:32 pm
Encrypted wrote:How do I enable detailed logging?
See my signature...
patters
Post Mon Mar 07, 2011 9:23 am
We pretty much have the same issue with Sony BDP. It seems to be that FFmpeg cannot remux a dts audio stream without breaking it.
Do the same thing manually with TSmuxer and the resulting file works. I'm going to submit it to the the FFmpeg issue tracker with sample files etc., tonight hopefully.
mback2k
Post Sat May 21, 2011 4:26 pm
patters wrote:I'm going to submit it to the the FFmpeg issue tracker with sample files etc., tonight hopefully.
Any news on the matter?
Post Mon May 23, 2011 3:52 pm
Not really...
On the version 0.7_beta1 changelog, you could found:
- IEC 61937 encapsulation for E-AC3, TrueHD, DTS-HD (for HDMI passthrough)
There were also a patch about "non monotone timestamps" error.
But I don't know if remuxing DTS into mpegts issue is solved.
