NEED HELP An unexpected error occurred (500). Check the log
trufreak
Post Sun Oct 19, 2014 2:44 am
I am trying to update my library and I keep getting a (500) error and I don 't know what the problem is I enabled the log feature but still do not understand what is wrong can someone help I attached the log file someone please help!
Log File
(224.38 KiB) Downloaded 443 times
Post Sun Oct 19, 2014 3:13 pm
Re: NEED HELP An unexpected error occurred (500). Check the
Are you using the same version for the server and the console? Are you using the console or a web UI?
trufreak
Post Sun Oct 19, 2014 3:25 pm
I have Serviio Console 1.4.1.2 Pro
I am using pro on my Samsung LED UN40F6300
everytime I try to delete a particular folder I get that (500) error and I dont know what to do to fix it
Post Sun Oct 19, 2014 4:54 pm
It looks like you DB missed some update during upgrade. Your best bet is a clean reinstall now.
