Can't run Serviio afte MAC update, need to install JAVA SE 6
newway
Post Sun Oct 19, 2014 8:01 pm
So I've been using Serviio for quite a while, but last night when I update my macbook to Yosemite, all of a sudden Serviio stopped working,
when I click "Serviio" it popup "To open Serviio you need to install the legacy Java SE 6 runtime". WTF? I have java 7/8 SDK and JRE installed
all along, do I have to download JAVA 6? surely that can't be right?
P.S. I updated Serviio to 1.4.1, same error, please help.
Post Sun Oct 19, 2014 10:17 pm
Re: Can't run Serviio afte MAC update, need to install JAVA
Java 6 is probably installed in a different location that 7/8. You might have to install 6 too. 1.5 will address this, but it's still some time away.
Post Mon Oct 20, 2014 8:32 am
mpi
Post Fri Nov 07, 2014 11:11 am
How is Java then invoked by Serviio?
Knowing this would help symlink with JRE8 files.
I tried linking each of
/System/Library/Frameworks/JavaVM.framework/Versions/A/Commands/java
/usr/bin/java
to JRE8's location
/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
but it won't solve the issue with Serviio 1.4.1.2
Thanks for any help
Post Tue Nov 11, 2014 7:27 pm
There is a Stub file, that looks for the Java executable in a location where java 6 was. java 8 is now installed in another location.
1.5 will come with embedded java, but in the meantime, you should install java 6 as per the above link.
buttcmd
Post Thu Nov 27, 2014 10:48 pm
if you want to run serviio with your own java and not with Java 6, you only need to run java yourself without using the javastub provided with the program(the javastub is used when you doeble click the serviio icon).
This is not a beautiful way but it works. It is pretty easy to make a script associated to an icon afterwards if it is needed/wanted.
To run the serviio server open a terminal and run this:
cd /Applications/Serviio.app/Contents/Resources/Java/;java -cp serviio.jar:commons-codec.jar:commons-imaging.jar:commons-io.jar:commons-jxpath.jar:commons-lang.jar:concurrent.jar:derby.jar:freemarker.jar:groovy-all.jar:gson.jar:httpcore.jar:jaudiotagger.jar:jcl-over-slf4j.jar:jcs.jar:jdom.jar:jnat-pmplib.jar:jul-to-slf4j.jar:log4j.jar:lucene-analyzers-common.jar:lucene-core.jar:org.restlet.ext.gson.jar:org.restlet.ext.net.jar:org.restlet.ext.xstream.jar:org.restlet.jar:padlock.jar:rome-modules.jar:rome.jar:sbbi-upnp.jar:serviio-media-browser-web.jar:serviio-media-browser.jar:slf4j-api.jar:slf4j-log4j12.jar:streamflyer-core.jar:winp.jar:xstream.jar:config org.serviio.MediaServer
To run the serviio-console (after you run the server) run this:
cd /Applications/Serviio-Console.app/Contents/Resources/Java;java -cp commons-codec.jar:jul-to-slf4j.jar:log4j.jar:org.restlet.ext.net.jar:org.restlet.ext.xstream.jar:org.restlet.jar:serviio-client.jar:serviio.jar:slf4j-api.jar:slf4j-log4j12.jar:xstream.jar:config org.serviio.console.ServiioConsole
jutre
Post Fri Dec 05, 2014 11:15 pm
buttcmd wrote:if you want to run serviio with your own java and not with Java 6, you only need to run java yourself without using the javastub provided with the program(the javastub is used when you doeble click the serviio icon).
Thanks for this suggestion buttcmd !
After doing step 1, I can see the serviio server in the list of processes (org.serviio.MediaServer). However, the console does not start with step 2. I am running Yosemite 10.10.1. Any idea why the console fails to start ?
