Serviio 1.4 keeps NAS (DS213) from sleeping?
olivex
Post Wed Jan 08, 2014 10:52 am
I set my NAS (Synology DS213) to hibernate after being idle for 10 minutes. It worked well before I installed Serviio. After I installed Serviio and set metadata update to every 7200 minutes (5 days), my NAS still waked up about every hour. If I shutdown Serviio then it could hibernate as expected.
Recently I updated to Serviio 1.4 and this gets worse. NAS doesn't hybernate at all.
I enabled DEBUG log and uploaded the log as attached. This log was gathered before I stopped Serviio. So in the log I can see that Serviio is always busy. It never stops.
Is there a way to set Serviio to stay idle when there is no external requests?
(137.18 KiB) Downloaded 563 times
npuser
Post Thu Jan 09, 2014 1:05 am
Re: Serviio 1.4 keeps NAS (DS213) from sleeping?
Besides checking frequency of library or meta refresh interval - you may also want to add following to JAVA_OPTS to see if it helps.
-Djava.util.prefs.syncInterval=9999999 -Dplugins.check=false
syncinterval milliseconds; constant new plugin check false
NPuser
olivex
Post Fri Jan 10, 2014 2:53 pm
npuser wrote:Besides checking frequency of library or meta refresh interval - you may also want to add following to JAVA_OPTS to see if it helps.
NPuser
I checked serviio.sh, the current value is 86400, and I think it is seconds not milliseconds, so it is 24 hours. It shouldn't wake up myNAS every hour?
As for plugins.check, I don't see a setting in the script. What is plugins anyway?
olivex
Post Sat Jan 11, 2014 12:48 am
NPuser
I changed syncinterval to 864000, which should be 240 hours, and plugins.check to false. And I set the lg level back to INFO. Now the NAS wakes up exactly every hour. I suspect it didnt go to sleep because the DEBUG log keep it running.
But my problem is still not solved. I wakes up every hour.
npuser
Post Mon Jan 13, 2014 12:01 am
Make sure orange box is check not green and red.
http://wiki.serviio.org/doku.php?id=pc5dczc_console_explained
NPuser
Edit: forgot to include a link
olivex
Post Mon Jan 13, 2014 3:50 am
npuser wrote:Make sure orange box is check not green and red.
NPuser
What is 'orange box'?
Also, from here:
https://bitbucket.org/xnejp03/serviio/i ... nt-7681289
Does it mean it was admitted as a bug?
Post Mon Jan 13, 2014 5:08 am
I will look at it for 1.4.1. can you provide detail log of around the time the nas wakes up and attach it to the ticket?
olivex
Post Mon Jan 13, 2014 11:57 am
zip wrote:I will look at it for 1.4.1. can you provide detail log of around the time the nas wakes up and attach it to the ticket?
Yes. The uploaded log in this post a bit earlier is a detailed log (with 'DEBUG' set). However, I noticed that, with 'DEBUG' set, the NAS never hibernates. While I look at the log, it seems Serviio is active every second, so I suspect the fact that detail log keeps writing prevents hibernation at all.
If I stop detail log, NAS hibernates but wakes up every exact hour. I have set media info refresh to 7200 min, syncinterval to 864000, and plugsin.check=false.
olivex
Post Mon Jan 13, 2014 8:26 pm
I'm pretty sure this wake-up-per-hour is caused by Serviio because if I stop Serviio, that wake-up disappears and the hibernation works as expected.
MarcelTheRadioMan1
Post Thu Apr 17, 2014 7:50 pm
I've Serviio 1.4.1.2 installed on a DS213j. After installation my NAS doesn't hybernate anymore. I'm pretty sure Serviio caused this problem. Please help!
NRB
Post Sun Jun 15, 2014 11:10 am
My DS413 still won't hibernate when serviio is running. When it's off, the NAS hibernates after 10 minutes as programmed to.
I've added "-Dplugins.check=false" as described.
NRB
Post Sat Jul 12, 2014 12:49 pm
I'm still experiencing no hibernation when Serviio's running on my NAS. Can anyone provide some advice?
snowflake7
Post Tue Jul 29, 2014 2:23 pm
Bump.
I have a DS412+ amd a DS214play. Both display the hibernate issue when the serviio package is running.
Is there a solution?
NRB
Post Wed Oct 22, 2014 11:26 pm
BUMP
olivex
Post Fri Oct 24, 2014 3:01 am
It's been a long time there is no update of this software.
Users browsing this forum: Baidu [Spider] and 28 guests
