cannot connect to servio server, does not appear to be runni
stache1
Post Thu Oct 23, 2014 5:28 pm
Servio has been running for a long time on my system, Windows 8.0 on an HP system.
Servio was downloaded 11/7/2013.
I updated JAVA to 1.8.20 on Tues Oct 21, 2014. It deleted an old version of Java to avoid problems, I do not remember the version but probably was the previous level of it.
Problem:
Opening servio the SevioConsole.exe file seems to be running, using 45.9MB with 0.1% CPU usage, but the connection seems to have a problem.
"Servio Error: Cannot connect to servio server, it does not seem to be running."
What could I have missed doing?
probedb
Post Fri Oct 24, 2014 8:31 am
Re: cannot connect to servio server, does not appear to be r
Have you checked the Event logs and also the Services to make sure it's running, if not then start it. If it fails it should generate an error in the Event Log which you can have a look at.
For info I'm running Java 8 and no issues.
stache1
Post Sat Oct 25, 2014 1:08 am
I do not remember which service controls the access rights, servio, windows sharing, or system? looked at a dln file setup page but it did not match with anything I could find.
Probably memory fade.
I M GETTING THE FOLLOWING MSGS IN THE LOG FILE.
lots of these
2014-10-21 10:14:03,135 WARN [LibraryAdditionsCheckerThread] Folder 'o:\My Pictures' is either not an existing directory or cannot be read due to access rights
2014-10-21 10:14:03,135 WARN [LibraryAdditionsCheckerThread] Folder 'c:\Users\jerry.jerry.000\My Pictures' is either not an existing directory or cannot be read due to access rights
2014-10-21 10:14:03,135 WARN [LibraryAdditionsCheckerThread] Folder 'O:\My Videos' is either not an existing directory or cannot be read due to access rights
2014-10-21 10:14:03,136 WARN [LibraryAdditionsCheckerThread] Folder 'C:\My Videos' is either not an existing directory or cannot be read due to access rights
2014-10-21 10:14:03,139 WARN [LibraryAdditionsCheckerThread] Folder 'C:\My Music' is either not an existing directory or cannot be read due to access rights
at the end I see a lot of these:
Initializing Serviio Console
2014-10-21 10:24:55,650 INFO [ServiioConsole] Starting Serviio Console
2014-10-21 10:25:02,291 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-10-21 10:25:14,793 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2014-10-21 10:25:25,106 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2014-10-21 10:25:25,121 INFO [Messages] Loaded console message bundle for locale: en
2014-10-21 10:25:54,750 INFO [ServiioConsole] Initializing Serviio Console
2014-10-21 10:25:54,781 INFO [ServiioConsole] Exitting Serviio Console
2014-10-21 10:26:17,608 INFO [ServiioConsole] Initializing Serviio Console
2014-10-21 10:26:17,624 INFO [ServiioConsole] Exitting Serviio Console
2014-10-21 10:26:23,125 INFO [ServiioConsole] Exitting Serviio Console
2014-10-21 10:27:20,847 INFO [ServiioConsole] Initializing Serviio Console
2014-10-21 10:27:20,862 INFO [ServiioConsole] Starting Serviio Console
2014-10-21 10:27:20,940 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-10-21 10:27:31,139 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2014-10-21 10:27:41,311 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
Post Sun Oct 26, 2014 7:07 pm
The Serviio service runs under a system user, you might have to change that to a real user that has access to these folders.
Users browsing this forum: No registered users and 59 guests
