Upnp Control Point sofware : Kinsky
Post Wed Aug 21, 2013 7:39 am
I found a good and simple windows application that provide a Upnp Control Point function: LINN Kinsky
Kinsky is an open source UPnP control point for iPod/iPhone, iPad, Windows, MacOSX, Linux, Android and PocketPC.
XIKO29
Post Thu Oct 23, 2014 7:36 pm
Re: Upnp Control Point sofware : Kinsky
Hi.
How can i use Kinsky with Serviio?
Post Fri Oct 24, 2014 9:29 am
You have to select Serviio as a "Source", a upnp TV as a "Room", then "push" media from source to room.
Not tested with latest version, I'm not using it now.
XIKO29
Post Fri Oct 24, 2014 7:40 pm
The problem is that Kinsky only detects my CA NP30 and the BubbleUPnP that i have on my Android, not the Serviio (installed in the same pc as Kinsky)
Post Sat Oct 25, 2014 12:18 pm
I install kinsky on my Windows 8
On Room, I select my Sony Bravia TV
On library, I select Ser'viio/ Video / ... then right click and select Play Now.
Kinsky push the video to my Sony Bravia TV.
On serviio console I have to select "Sony Bravia Profile" for the PC device where Kinsky was installed (Windows MediaPlayer).
XIKO29
Post Sat Oct 25, 2014 1:57 pm
Ok, i'll try that.
XIKO29
Post Sat Oct 25, 2014 10:05 pm
Still no luck :(
Return to General discussion
