Good Xbox One Profile?
jumperzz2014
Post Wed Oct 01, 2014 12:22 pm
Anyone with a good XboxOne profile? The default one has really low quality audio transcoding.
Need a profile that transcodes DTS to Ac3 but still in high Quality.
For now im using the WMP Profile with the XboxOne
Post Sun Oct 19, 2014 5:01 pm
Re: Good Xbox One Profile?
You can try to set the aBitrate attribute in the profile, like:
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="XXX">
where XXX is the kbit value.
jumperzz2014
Post Sun Oct 26, 2014 3:27 am
Wow thanks for that tip. That worked :D
I used 640 as value, works fine :)
TenchiZ
Post Tue Mar 24, 2015 7:24 am
+1. Thanks so much... couldn't figure out for the life of me why all my MKVs sounded like junk when streaming them to my Xbox One. Adjusting the bitrate did the trick (I also used 640).
As an aside, it would be awesome to be able to set a target bitrate in the console and have it aim for that unless specifically overridden by the profile.
