online feed plays with VLC, but not with Serviio
I used to have a feed with a rtsp address working fine in serviio, now the feed has changed to http, and is no longer accessible from Serviio online stream, however, vlc can play the feed.
the address is
http://manoto1_live-lh.akamaihd.net/i/M ... 0eb353c148
here is the log when I use ffmpeg -i
[mpegts @ 0xbac77e0] max_analyze_duration 5000000 reached at 5014800 microseconds
[mpegts @ 0xbac77e0] Could not find codec parameters for stream 2 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[h264 @ 0xb55d660] Missing reference picture, default is 0
[h264 @ 0xb55d660] decode_slice_header error
[h264 @ 0xb15e480] Missing reference picture, default is 0
[h264 @ 0xb15e480] decode_slice_header error
[h264 @ 0xb0e0040] Missing reference picture, default is 0
[h264 @ 0xb0e0040] decode_slice_header error
[h264 @ 0xb565c80] Missing reference picture, default is 0
[h264 @ 0xb565c80] decode_slice_header error
[h264 @ 0xb0bb940] Missing reference picture, default is 0
[h264 @ 0xb0bb940] decode_slice_header error
[h264 @ 0xb313080] Missing reference picture, default is 0
[h264 @ 0xb313080] decode_slice_header error
[h264 @ 0xb1d36a0] Missing reference picture, default is 0
[h264 @ 0xb1d36a0] decode_slice_header error
[h264 @ 0xb15fa60] Missing reference picture, default is 0
[h264 @ 0xb15fa60] decode_slice_header error
[h264 @ 0xba1e900] Missing reference picture, default is 0
[h264 @ 0xba1e900] decode_slice_header error
[hls,applehttp @ 0xb089e00] max_analyze_duration 5000000 reached at 5014800 microseconds
[hls,applehttp @ 0xb089e00] Could not find codec parameters for stream 2 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
[hls,applehttp @ 0xb089e00] Could not find codec parameters for stream 5 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
[hls,applehttp @ 0xb089e00] Could not find codec parameters for stream 8 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
[hls,applehttp @ 0xb089e00] Could not find codec parameters for stream 11 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
[hls,applehttp @ 0xb089e00] Could not find codec parameters for stream 14 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
[hls,applehttp @ 0xb089e00] Could not find codec parameters for stream 17 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
[hls,applehttp @ 0xb089e00] Could not find codec parameters for stream 20 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
[hls,applehttp @ 0xb089e00] Could not find codec parameters for stream 23 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
[hls,applehttp @ 0xb089e00] Could not find codec parameters for stream 26 (Unknown: none ([21][0][0][0] / 0x0015)): unknown codec
[hls,applehttp @ 0xb089e00] Estimating duration from bitrate, this may be inaccurate
Input #0, hls,applehttp, from 'http://manoto1_live-lh.akamaihd.net/i/Manoto1_0@50710/master.m3u8?hdnea=st=1414523229~exp=1414539429~acl=/*~hmac=a1133742dae6ff07ab162b06a08ad46f61f4ba2749c9cf7f32db840eb353c148':
Duration: 00:00:00.13, start: 50093.956467, bitrate: 106 kb/s
Program 0
variant_bitrate : 72000
Stream #0:0: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 43 kb/s
Stream #0:2: Unknown: none ([21][0][0][0] / 0x0015)
Program 1
variant_bitrate : 256000
Stream #0:3: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:4: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 68 kb/s
Stream #0:5: Unknown: none ([21][0][0][0] / 0x0015)
Program 2
Stream #0:6: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:7: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 68 kb/s
Stream #0:8: Unknown: none ([21][0][0][0] / 0x0015)
Program 3
variant_bitrate : 448000
Stream #0:9: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:10: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 68 kb/s
Stream #0:11: Unknown: none ([21][0][0][0] / 0x0015)
Program 4
Stream #0:12: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:13: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 73 kb/s
Stream #0:14: Unknown: none ([21][0][0][0] / 0x0015)
Program 5
variant_bitrate : 832000
Stream #0:15: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:16: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 64 kb/s
Stream #0:17: Unknown: none ([21][0][0][0] / 0x0015)
Program 6
Stream #0:18: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:19: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 60 kb/s
Stream #0:20: Unknown: none ([21][0][0][0] / 0x0015)
Program 7
variant_bitrate : 1600000
Stream #0:21: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:22: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 64 kb/s
Stream #0:23: Unknown: none ([21][0][0][0] / 0x0015)
Program 8
Stream #0:24: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:25: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 61 kb/s
Stream #0:26: Unknown: none ([21][0][0][0] / 0x0015)
any idea on how I can play the feed?
the address is
Program 0
Program 1
Program 2
Program 3
Program 4
Program 5
Program 6
Program 7
Program 8
