[SOLVED] Sopcast stream on 50W805B - a black screen?
So I can get Sopcast to run perfectly on the Samsung 55inch in the living room (except for the cutting out every minute or so, but I've read that issue is solvable). Also it works so smoothly that I don't even think it's trans-coding at all, unless I'm mistaken?
But on my Sony Bravia KDL-50W805B in my bedroom, when I play the Sopcast stream all I get is a black screen.
I doubt this TV's media capabilities are any less than the Samsung. In fact it's slightly better since it can play 60fps smoothly and the Samsung doesn't play any of those.
Can anyone help?
EDIT: So I've managed to get the picture working thanks to the code in this post:
viewtopic.php?p=94549#p94549
Only problem now is no audio.
