Using FFMPEG live stream
ppetrov
Post Tue Oct 28, 2014 9:28 am
I'm working on an application generating live stream, which hast to be rendered on a Smart TV.
As FFMPEG cannoct act as DLNA server, the solution as I see it is to setup a FFSERVER stream, and use a link to it as Source URL when configuring SERVIIO Live stream. In my case, the FFSERVER stream configuration is:
<Stream rtmp1.webm>
   Format rtp
   Feed rtmp1.ffm
   MulticastAddress 225.1.1.12
   MulticastPort 5000
   MulticastTTL 16
   NoLoop
   VideoCodec libvpx
   VideoFrameRate 25
   VideoBitRate 400
   VideoSize 384x224
   AVOptionVideo default
   AVOptionVideo main
   AVOptionVideo flags +global_header
   AudioCodec vorbis
   AudioBitRate 48
   AudioChannels 1
   AudioSampleRate 44100
   AVOptionAudio flags +global_header
</Stream>
And the path set as SERVIIO Source URL is:
rtsp://225.1.1.12:5000/rtmp1.webm
Unfortunatelly, pressing <Check stream URL> causes the red cross to appear --- error. The FFSERVER reacts, it dums the next line to its console:
Tue Oct 28 10:59:51 2014 192.168.2.16 - - [OPTIONS] " " 200 0
This means at least, that both systems communicate - but obviously something is wrong: the SERVIIO source URL or the FFMPEG configuration.
Has someone already succeeded to use FFMPEG stream as source for SEVIIO?
Regards,
Plamen
Post Tue Oct 28, 2014 1:04 pm
Re: Using FFMPEG live stream
try ffplay -i rtsp://225.1.1.12:5000/rtmp1.webm to ensure the stream exists.
ppetrov
Post Wed Oct 29, 2014 7:25 pm
jhb50 wrote:try ffplay -i rtsp://225.1.1.12:5000/rtmp1.webm to ensure the stream exists.
The stream doesn't work, the error message is:
rtsp://192.168.2.16:8090/rtmp1.webm: Invalid data found when processing input
I have posted to the FFMPEG forum too, no answer so far. The topick is interesting, I believe that someone uses FFMPEG with DLNA server, SERVIIO too, for streaming directly to TV. Hope that someone answers!
Regards,
Plamen
Post Sat Nov 01, 2014 5:36 pm
Serviio might reject /ignore the OPTION request.
ppetrov
Post Sat Nov 01, 2014 6:23 pm
zip wrote:Serviio might reject /ignore the OPTION request.
In this case, it won't work at all. Isn't FFMPEG tested as stream source for SERVIIO yet?
Post Sat Nov 01, 2014 9:42 pm
That tells me your stream does not exist or is an invalid format.
ppetrov
Post Mon Nov 03, 2014 9:48 am
This is what I've posted to the FFMPEG forum. My last post there describes the tests by a RTMP ffserver stream. FFPLAY connects to it, but it hangs.
By now I'm a little bit desperated about this idea - since the FFMPEG experts cannot help, it could be that this case isn#t tested by now. I can't believe it, but since I can't find any info into the Internet...
Regards,
Users browsing this forum: Baidu [Spider] and 23 guests
