YouTube
Post Sat Apr 26, 2014 8:21 am
Re: YouTube
andreluigo wrote:I give up... It seems anyone won't help me!
Post in the support forums with the required information (check out the Readme first topic). We can't help without if you don't provide any details.
Ultimat
Post Sat Apr 26, 2014 9:05 pm
Re: YouTube
How about my question?
If you prefer, possible. can use youtube-dl with this plugin to work with troubled videos.
Now all of playlists videos I can watch on TV. youtube-dl used for get link with correct signature.
If you want details - write private Messages.
shrx
Post Sun Aug 17, 2014 11:31 pm
Re: YouTube
Can anyone test if this video works?
http://gdata.youtube.com/feeds/api/vide ... -results=1
I've been watcthing the playlist http://gdata.youtube.com/feeds/api/play ... y=position and this video was missing. I tried to add it separately but it won't show up.
Using Serviio 1.4.1.2 on OS X, TV is Philips 32PFL9705H.
liru
Post Fri Oct 31, 2014 2:06 pm
Re: YouTube
Hello all,
I have installed Serviio on my Zyxel NAS, model NSA320S and it works perfectly fine. However, no matter what I've tried, I cannot make any youtube clips to work, under "online souces".
I have downloaded the plugin from here and copied it to the following folder on the NAS: /ffp/opt/serviio/plugins/
I have set up in the cosole the clips according the the instructions on the Serviio wiki page
The url looks like this: http://gdata.youtube.com/feeds/api/vide ... xxxxxxxxxx
On the LG media player I can see the clips listed in the "online folder", but when I try to play any of them I get the message "No Content Available".
I have tried the exact same setup with Serviio server on my PC and the youtube online sources play with no problem.
Can you please help me to find out what I'm doing wrong on the NAS setup?
Many thanks.
Post Fri Oct 31, 2014 4:10 pm
Re: YouTube
Depends on the clip. Some are encoded or explicit and Serviio plugin does not support them.
If you post the code I will check them.
liru
Post Fri Oct 31, 2014 4:33 pm
Re: YouTube
Ok, here is the log from /ffp/opt/serviio/log/
Many thanks for your kelp!
Part 1
2014-10-25 21:09:23,550 INFO  [UpdateChecker] Checking if a new version is available
2014-10-25 21:31:29,874 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-25 21:31:29,955 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-25 21:31:36,822 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-25 21:31:36,961 INFO  [SearchManager] Starting up search engine
2014-10-25 21:31:41,255 INFO  [LibraryAdditionsCheckerThread] Added file 'Sin.City.2005.720p.BluRay.x264.RoSubbed-SEPTiC.mkv' (title: Sin.City.2005.720p.BluRay.x264.RoSubbed-SEPTiC) to Library
2014-10-25 21:31:44,919 INFO  [LibraryAdditionsCheckerThread] Added file 'Hitchcock.2012.720p.BluRay.DD5.1.x264-CRiSC.mkv' (title: Hitchcock.2012.720p.BluRay.DD5.1.x264-CRiSC) to Library
2014-10-25 21:31:46,330 INFO  [LibraryAdditionsCheckerThread] Added file 'Sin.City.A.Dame.to.Kill.For.2014.720p.BluRay.DTS.x264-TayTO.mkv' (title: Sin.City.A.Dame.to.Kill.For.2014.720p.BluRay.DTS.x264-TayTO) to Library
2014-10-25 21:31:49,723 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-25 21:31:51,937 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-25 21:31:53,364 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-26 21:09:23,554 INFO  [UpdateChecker] Checking if a new version is available
2014-10-27 14:24:51,597 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2014-10-27 14:24:52,317 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-27 14:24:55,717 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtsp://r4---sn-4g57kuee.c.youtube.com/CiILENy73wIaGQkuOgIETQkIUhMYDSANFEgGUgZ2aWRlb3MM/0/0/0/video.3gp. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:297)
   ... 2 more
2014-10-27 14:24:56,892 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-27 14:24:56,906 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-27 14:25:02,500 INFO  [LibraryAdditionsCheckerThread] Added file 'Adolf_20Hitler-The_20Man_20Against_20Time.avi' (title: Adolf_20Hitler-The_20Man_20Against_20Time) to Library
2014-10-27 14:25:04,856 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-27 14:25:06,848 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-27 14:25:08,346 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-27 14:25:09,197 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-27 14:25:31,252 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2014-10-27 14:25:31,311 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-27 14:25:31,391 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-27 14:25:31,338 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-27 14:25:40,499 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-27 14:25:41,541 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-27 20:36:56,900 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-27 20:36:56,901 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-27 20:36:56,902 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2014-10-27 20:36:56,976 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-27 20:36:57,030 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-27 20:36:57,032 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-27 20:37:03,451 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-27 20:37:04,743 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-27 21:09:23,552 INFO  [UpdateChecker] Checking if a new version is available
2014-10-27 21:30:03,333 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-27 21:30:03,335 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-27 21:30:03,336 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2014-10-27 21:30:03,461 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-27 21:30:03,473 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-27 21:30:03,542 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-27 21:30:09,777 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-27 21:30:10,809 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-27 21:32:16,359 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-27 21:32:16,361 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-27 21:32:16,362 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2014-10-27 21:32:16,468 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-27 21:32:16,512 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-27 21:32:16,522 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-27 21:32:28,971 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-27 21:32:30,044 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-27 21:33:55,810 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-27 21:33:55,811 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-27 21:33:55,811 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2014-10-27 21:33:55,919 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-27 21:33:55,942 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-27 21:33:55,947 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-27 21:34:04,008 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-27 21:34:05,034 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-27 21:34:35,417 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-27 21:34:35,418 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-27 21:34:35,418 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2014-10-27 21:34:35,546 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-27 21:34:35,563 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-27 21:34:35,582 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-27 21:34:43,281 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-27 21:34:44,344 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-28 09:34:54,806 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-28 09:34:56,237 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-28 14:07:50,820 INFO  [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy), version: 1
2014-10-28 14:11:53,553 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-28 14:11:53,554 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-28 14:11:53,655 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2014-10-28 14:11:53,769 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-28 14:11:53,847 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-28 14:11:53,855 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-28 14:12:04,588 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?signature=2101F27EF9045AE8CE3C4C8B1A7BE42F42A0AE39.3204A226167EB57E2725E25514FE17DEEEC2BD57&mm=31&ipbits=0&id=o-AAtaSL4XxP_vjzyaNZRl48Xb9t_iwqkMM3IqmQN6kozn&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&fexp=904843%2C924628%2C927622%2C930666%2C930672%2C931983%2C932404%2C939109%2C947209%2C952302%2C952901%2C957103&upn=SkaFGPTXofQ&ms=au&itag=18&initcwndbps=4330000&mv=m&source=youtube&sver=3&ip=188.25.25.138&key=yt5&expire=1414527118&mt=1414505320&ratebypass=yes. It might not play.
   ... 2 more
2014-10-28 14:12:04,841 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-28 14:12:06,609 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-28 16:28:34,171 INFO  [MediaServer] ------------------------------------------------------------------------
2014-10-28 16:28:34,244 INFO  [MediaServer] Serviio DLNA media streaming server v 1.3.1 (rev. f1fc8bc55657+)
2014-10-28 16:28:34,245 INFO  [MediaServer] Petr Nejedly 2009-2013
2014-10-28 16:28:34,245 INFO  [MediaServer] http://www.serviio.org
2014-10-28 16:28:34,246 INFO  [MediaServer] Java 1.7.0_60-Oracle Corporation
2014-10-28 16:28:34,246 INFO  [MediaServer] OS Linux arm 2.6.31.8
2014-10-28 16:28:34,247 INFO  [MediaServer] File encoding: US-ASCII
2014-10-28 16:28:34,250 INFO  [MediaServer] Headless mode enabled: true
2014-10-28 16:28:34,251 INFO  [MediaServer] User: root
2014-10-28 16:28:34,253 INFO  [MediaServer] User home dir: /root
2014-10-28 16:28:34,253 INFO  [MediaServer] Temp dir: /tmp
2014-10-28 16:28:34,253 INFO  [MediaServer] ------------------------------------------------------------------------
2014-10-28 16:28:37,343 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-10-28 16:28:37,377 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-10-28 16:28:38,087 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-10-28 16:28:38,090 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-10-28 16:28:38,473 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-10-28 16:28:56,507 INFO  [Device] Created UPnP Device with UUID: 21a42ca8-fe92-38dd-a3b0-eb6909482417, bound address: 192.168.0.45
2014-10-28 16:28:57,274 INFO  [prefs] Created user preferences directory.
2014-10-28 16:28:58,658 INFO  [MediaServer] ------------------------------------------------------------------------
2014-10-28 16:28:58,658 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2014-10-28 16:28:58,659 INFO  [MediaServer] ------------------------------------------------------------------------
2014-10-28 16:29:03,081 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-10-28 16:29:03,673 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2014-10-28 16:29:03,745 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2014-10-28 16:29:03,769 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2014-10-28 16:29:03,786 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2014-10-28 16:29:03,801 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2014-10-28 16:29:03,831 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2014-10-28 16:29:03,847 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E/F-series)' (id=7)
2014-10-28 16:29:03,851 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2014-10-28 16:29:03,894 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2014-10-28 16:29:03,921 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2014-10-28 16:29:03,939 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2014-10-28 16:29:03,942 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2014-10-28 16:29:03,945 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2014-10-28 16:29:03,949 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2014-10-28 16:29:03,989 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2014-10-28 16:29:03,992 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2014-10-28 16:29:04,006 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2014-10-28 16:29:04,010 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2014-10-28 16:29:04,014 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2014-10-28 16:29:04,017 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2014-10-28 16:29:04,020 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2014-10-28 16:29:04,024 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2014-10-28 16:29:04,027 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2014-10-28 16:29:04,030 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2014-10-28 16:29:04,035 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2014-10-28 16:29:04,039 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2014-10-28 16:29:04,041 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2014-10-28 16:29:04,044 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2014-10-28 16:29:04,056 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2014-10-28 16:29:04,058 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2014-10-28 16:29:04,063 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2014-10-28 16:29:04,065 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2014-10-28 16:29:04,068 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2014-10-28 16:29:04,082 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2014-10-28 16:29:04,084 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2014-10-28 16:29:04,087 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2014-10-28 16:29:04,090 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2014-10-28 16:29:04,092 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2014-10-28 16:29:04,473 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-10-28 16:29:04,559 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2014-10-28 16:29:04,564 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2014-10-28 16:29:04,578 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2014-10-28 16:29:04,581 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2014-10-28 16:29:04,585 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2014-10-28 16:29:04,608 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2014-10-28 16:29:04,613 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2014-10-28 16:29:05,010 INFO  [PluginCompilerThread] Looking for plugins at /ffp/opt/serviio/plugins
2014-10-28 16:29:05,020 INFO  [UpdateChecker] Checking if a new version is available
2014-10-28 16:29:05,050 INFO  [PluginCompilerThread] Started looking for plugins
2014-10-28 16:29:05,961 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version 1.2.1 Copyright (c) 2000-2013 the FFmpeg developers
2014-10-28 16:29:05,962 WARN  [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2014-10-28 16:29:05,962 WARN  [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsubs) will not work.
2014-10-28 16:29:07,838 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, No such file or directory
java.io.IOException: Cannot run program "dcraw": error=2, No such file or directory
   at java.lang.ProcessBuilder.start(ProcessBuilder.java:1041)
   at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: error=2, No such file or directory
   at java.lang.UNIXProcess.forkAndExec(Native Method)
   at java.lang.UNIXProcess.<init>(UNIXProcess.java:186)
   at java.lang.ProcessImpl.start(ProcessImpl.java:130)
   at java.lang.ProcessBuilder.start(ProcessBuilder.java:1022)
   ... 1 more
2014-10-28 16:29:07,853 WARN  [MediaServer] DCRAW not found. Support for raw image files will be missing.
2014-10-28 16:29:08,010 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-10-28 16:29:08,489 INFO  [WebServer] WebServer starting on port 8895
2014-10-28 16:29:08,495 INFO  [Device] Updated bound IP address of Device with UUID: 21a42ca8-fe92-38dd-a3b0-eb6909482417, bound address: 192.168.0.45
2014-10-28 16:29:08,662 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface egiga0 (egiga0) and address 192.168.0.45, timeout = 0
2014-10-28 16:29:08,664 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-10-28 16:29:08,669 INFO  [EventDispatcher] Starting EventDispatcher
2014-10-28 16:29:08,688 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-10-28 16:29:08,706 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2014-10-28 16:29:08,748 INFO  [RendererSearchSender] Searching for Renderer devices
2014-10-28 16:29:15,523 INFO  [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy), version: 1
2014-10-28 16:29:35,167 INFO  [FeedUpdaterThread] Started looking for information about online resources
2014-10-28 16:29:35,185 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-28 16:29:35,361 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-28 16:29:35,366 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-28 16:29:50,238 INFO  [SearchManager] Starting up search engine
2014-10-28 16:29:57,368 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-28 16:30:01,173 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-28 16:30:02,867 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r5---sn-c0q7lnel.googlevideo.com/videoplayback?sver=3&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&ratebypass=yes&expire=1414535386&ip=188.25.25.138&mm=31&itag=18&mv=m&upn=Ap-cWN1AoNs&mt=1414513740&ms=au&signature=AB8724CA5423E3D78C2FC3C32A062E9E16B5D572.02F7B731493846CD4B96DCF8B05F7EDF22B0B043&fexp=900147%2C927622%2C930666%2C930672%2C931983%2C932404%2C940213%2C947209%2C952302%2C952901%2C957103&id=o-ALevJFqxlZ5oHbQPSE-1qOf5DYEZ7106kyLUvEa2qYDl&key=yt5&ipbits=0&initcwndbps=3096250&source=youtube. It might not play.
   ... 2 more
2014-10-28 17:01:17,614 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2014-10-28 17:01:26,835 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2014-10-28 18:03:23,266 INFO  [RendererManager] Stored a new renderer: uuid='791630cf-b8df-4d3f-9046-9e59e7055040', name = 'Unrecognized device', ipAddress='192.168.0.37', profile = '1'
2014-10-28 22:25:11,598 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?itag=18&signature=0B3B4E43E26D4C8F3A9065784190EFDCE6202A3E.1BC886A1F56FEE3B936F3FF642FD76B0FB1F6ABC&source=youtube&mv=m&mt=1414535016&ratebypass=yes&ip=188.25.25.138&ms=au&sver=3&mm=31&id=o-AMH7UmthH9lr25jRbM06rv6KUTot40odbWaSxyvk01jM&initcwndbps=4511250&key=yt5&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&expire=1414556709&ipbits=0&upn=-z3MO6uU_rQ&fexp=900245%2C916635%2C927622%2C930666%2C930672%2C932404%2C935681%2C938628%2C947209%2C947215%2C948118%2C952302%2C952901%2C957103. It might not play.
   ... 2 more
2014-10-28 23:30:19,624 INFO  [LibraryUpdatesCheckerThread] Removing 'Sin.City.2005.720p.BluRay.x264.RoSubbed-SEPTiC' (/i-data/md0/video/--- Filme ---/HD/Sin.City.2005.720p.BluRay.x264.RoSubbed-SEPTiC/Sin.City.2005.720p.BluRay.x264.RoSubbed-SEPTiC.mkv) from Library
2014-10-29 04:20:18,160 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?ipbits=0&sver=3&ratebypass=yes&expire=1414578016&initcwndbps=5298750&source=youtube&upn=8XQVEZVZrwg&mm=31&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&id=o-AJX-x583pCZPtsc6SxZoukSE4KAgSdUmXglyzK-kDYc0&signature=B10E102A2B1899CBE110DDC611038E5EE41B62FE.CB25A612762CB1336F2CD76C725FAFFCBE3AD665&itag=18&ip=188.25.25.138&mt=1414556321&mv=m&key=yt5&fexp=902543%2C922245%2C927622%2C929305%2C930666%2C930672%2C932404%2C945074%2C947209%2C948703%2C952302%2C952901%2C955100%2C957103&ms=au. It might not play.
   ... 2 more
2014-10-29 04:30:07,654 INFO  [LibraryAdditionsCheckerThread] Added file 'Sin.City.2005.720p.BluRay.x264.RoSubbed-SEPTiC.mkv' (title: Sin.City.2005.720p.BluRay.x264.RoSubbed-SEPTiC) to Library
2014-10-29 04:30:11,011 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-29 04:30:13,804 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-29 10:15:31,275 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?itag=18&ip=188.25.25.138&ms=au&mv=m&mt=1414577680&ratebypass=yes&id=o-AGfCqNFsJ3FSLO1IFrp2iPhvPNonsOrpagPKPLqTbR3I&sver=3&mm=31&signature=63979262FC30954C13BD0CF21AF1D1DB3D030F3F.10AA1B56BF498E3E16637FF439A84B4190C4ECBD&initcwndbps=4465000&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&source=youtube&fexp=901809%2C908208%2C924639%2C927622%2C930666%2C930672%2C932404%2C935667%2C936109%2C939973%2C942704%2C946201%2C947209%2C947215%2C948526%2C952302%2C952901%2C957103&expire=1414599329&ipbits=0&upn=jaMKHGZD7s4&key=yt5. It might not play.
   ... 2 more
2014-10-29 16:10:37,952 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r5---sn-c0q7lnel.googlevideo.com/videoplayback?sver=3&id=o-AJG77DJvtIXK9ZSahGjXI_0SGj9XcPupJfcUlfrbvdSc&source=youtube&ratebypass=yes&fexp=914099%2C924638%2C927622%2C930666%2C930672%2C932404%2C935639%2C938688%2C939109%2C947209%2C948703%2C952302%2C952901%2C957103&upn=yrXSJLmB-SA&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&expire=1414620635&signature=8EDCFBDB98FA5B0A02647EF3392149C756205210.231866C256E211EB810A15E6C950F859633C5804&ms=au&ipbits=0&initcwndbps=3171250&mv=m&mt=1414598944&itag=18&mm=31&key=yt5&ip=188.25.25.138. It might not play.
   ... 2 more
2014-10-29 16:29:05,028 INFO  [UpdateChecker] Checking if a new version is available
2014-10-29 16:30:20,197 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-29 16:30:21,912 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-29 22:05:45,605 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?sver=3&mt=1414620270&key=yt5&signature=1CB7A2252C8F27293E5BD098948826FEDF8C179D.213C256CBA6B615E31C11F9D303505392BBC8A6A&upn=BuljXRwTv7U&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&itag=18&expire=1414641943&source=youtube&mv=m&ratebypass=yes&ms=au&ip=188.25.25.138&ipbits=0&initcwndbps=4368750&mm=31&id=o-AOQKXwKZtbURfCZ_pPbWvGolgjY8ixcmk49STBeKufJG&fexp=901099%2C901494%2C914005%2C917000%2C927622%2C930666%2C930672%2C930824%2C931985%2C932404%2C938682%2C945257%2C947209%2C952302%2C952901%2C953912%2C957103. It might not play.
   ... 2 more
2014-10-29 22:49:20,280 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-29 22:49:20,382 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-29 22:49:20,493 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2014-10-29 22:49:20,854 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-29 22:49:20,892 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-10-29 22:49:20,892 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-29 22:49:29,505 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r2---sn-gqn-vu2e.googlevideo.com/videoplayback?mm=31&id=o-AN5dlZWzcMSfAiqaCg19IxIpNJFF5SLP-CmHWVOovEVW&source=youtube&itag=18&key=yt5&ratebypass=yes&mt=1414622918&mv=m&fexp=927622%2C930666%2C930672%2C932404%2C941289%2C947209%2C952302%2C952901%2C953912%2C957103&ms=au&ip=188.25.25.138&sver=3&initcwndbps=4676250&signature=75E5FBE84A28CA65B4F8CE74A0E9BCF4F756BCD6.9420680A1772350711F3728AB429F1A801BD62CE&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&ipbits=0&upn=hcEQ46jKphI&expire=1414644566. It might not play.
   ... 2 more
2014-10-29 22:49:33,916 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-29 22:49:35,394 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-29 22:59:19,507 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-29 22:59:19,509 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-29 22:59:19,512 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-29 22:59:19,512 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-29 22:59:26,840 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-29 22:59:27,978 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-30 04:01:38,909 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?ip=188.25.25.138&key=yt5&ipbits=0&itag=18&mm=31&mv=u&mt=1414641554&ms=au&id=o-AH2u5jz8cj7dsox5K6MG20qhH_TApnzzOnSo3tSTeSVk&signature=E66C7F8888909ED726C977171EF90A1B3C9EB741.785EBFD0314D05FFB5FB235250396D735A1DE574&expire=1414663297&sparams=id%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&upn=ekdPQ47MvZ0&fexp=902545%2C922243%2C927622%2C930666%2C930672%2C932404%2C934040%2C938644%2C942702%2C947209%2C947215%2C949501%2C951701%2C952302%2C952901%2C953912%2C957103%2C958600&ratebypass=yes&source=youtube&sver=3. It might not play.
   ... 2 more
2014-10-30 04:44:41,339 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r2---sn-gqn-vu2e.googlevideo.com/videoplayback?mt=1414644096&mm=31&fexp=914100%2C924639%2C927622%2C930666%2C930672%2C932404%2C934040%2C935666%2C941395%2C947209%2C947215%2C951500%2C952302%2C952901%2C953911%2C953912%2C957103&ms=au&itag=18&initcwndbps=4647500&mv=m&ratebypass=yes&source=youtube&key=yt5&ipbits=0&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&upn=OBIlNJO6Blg&signature=1611D4F18D28E43F150F0F1A3F8C5D338A6A15D4.76E13178A0A7ED478A277FB38DB57FCEF756CF38&ip=188.25.25.138&sver=3&id=o-ADXQFqz3zOta_cFh5e8Gn-9NTehzUS1xu-yKMys8-n9_&expire=1414665880. It might not play.
   ... 2 more
2014-10-30 09:56:49,704 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?sver=3&expire=1414684608&signature=A17F0D53DC06539686BE385ED55A5F61210AD406.090387FD52BF91966F200ABE705B3A837BE5EE09&ms=au&id=o-ANskxvxE-VcJyKtaummaLmcCGY0ysLf29dPWIJuNKSO9&mv=m&mt=1414662786&mm=31&source=youtube&initcwndbps=4413750&ip=188.25.25.138&fexp=924628%2C927622%2C930666%2C930672%2C932404%2C934040%2C939982%2C945243%2C947209%2C947215%2C948807%2C952302%2C952901%2C953912%2C957103%2C959200&itag=18&ratebypass=yes&ipbits=0&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&upn=uYMQGLANXpE&key=yt5. It might not play.
   ... 2 more
2014-10-30 10:39:52,145 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r2---sn-gqn-vu2e.googlevideo.com/videoplayback?source=youtube&ip=188.25.25.138&ipbits=0&initcwndbps=4137500&mv=m&fexp=900147%2C927622%2C930666%2C930672%2C932404%2C934040%2C940213%2C947209%2C947215%2C952302%2C952901%2C953912%2C957103&ms=au&mm=31&expire=1414687191&key=yt5&id=o-APANfTpJBEJ535YCiETK0an-VP3nib4BwM18t4pR3Mcg&upn=b7uyTvZDMco&itag=18&mt=1414665448&signature=AD4C30012E8AB79D30E9841BDC9241063A6CA959.994E6C5CF62C677182DF02F3A9A0AB1C1E5CF998&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&ratebypass=yes&sver=3. It might not play.
   ... 2 more
2014-10-30 10:59:32,992 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-30 10:59:34,352 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-30 15:51:59,690 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r5---sn-c0q7lnel.googlevideo.com/videoplayback?sver=3&signature=0B8CC95F99ACCFC20F3A22079149AE90F065AF8C.E13052FC6C37FB73F01C23BB5061F17D619DCDF3&ms=au&id=o-AOuzG_ju9f53vr3amOQJl1NJ8oPMkpVzbY3_BM7_ABuX&mv=m&mt=1414684160&source=youtube&mm=31&fexp=902545%2C927622%2C927880%2C930666%2C930672%2C932404%2C934040%2C936117%2C947209%2C947215%2C952302%2C952901%2C953912%2C957103%2C957201&ipbits=0&ratebypass=yes&ip=188.25.25.138&expire=1414705917&itag=18&upn=T7aNCMW5Rj4&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&initcwndbps=2977500&key=yt5. It might not play.
   ... 2 more
2014-10-30 16:29:05,023 INFO  [UpdateChecker] Checking if a new version is available
2014-10-30 16:35:02,902 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r12---sn-c0q7ln7y.googlevideo.com/videoplayback?id=o-ADUa0l2THQM6NFV_zi5PtJ8sUa6YhTlCIfA6BuiNrQV1&mm=31&signature=D6C0669EEEEBCAC4A35F6496784487A9B3FE4A49.4A3035FBDCA48DE9C5C657FC0786DE7CADA9370D&ip=188.25.25.138&key=yt5&itag=18&ms=au&fexp=927622%2C930666%2C930672%2C932404%2C934040%2C936118%2C945240%2C947209%2C947215%2C948703%2C952302%2C952901%2C953912%2C957103%2C957201&mt=1414686796&mv=m&sver=3&ratebypass=yes&initcwndbps=2752500&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&expire=1414708501&upn=TOT21v3OChw&ipbits=0&source=youtube. It might not play.
   ... 2 more
2014-10-30 21:47:10,109 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vhge.googlevideo.com/videoplayback?ipbits=0&ratebypass=yes&itag=18&sver=3&ip=188.25.25.138&mm=31&mv=m&mt=1414705550&ms=au&id=o-AJEIlyM4_oPVfpfnw_aoC4YsLZM0xIHmS3camr4TyNMt&expire=1414727228&upn=jDhcva_ZKy0&key=yt5&source=youtube&initcwndbps=3765000&fexp=900222%2C923345%2C930666%2C932404%2C934040%2C935688%2C937407%2C938682%2C940630%2C947209%2C947215%2C948524%2C951404%2C952302%2C952901%2C953912%2C957103%2C957201&signature=98CE0FE8773C93D49088B3864F07F93CBCB286A1.5A0075659A4456FDC721BF9012F71D6644BCE422&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire. It might not play.
   ... 2 more
2014-10-30 22:30:13,141 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r2---sn-gqn-vu2e.googlevideo.com/videoplayback?upn=DK21HiGH5XQ&signature=688BADF1878B86D6130BA6F758F153A6DA8C24BB.694182AD4FCD76044884D1935F8D25A3EF11955B&itag=18&ratebypass=yes&ipbits=0&expire=1414729811&mt=1414708043&mm=31&ip=188.25.25.138&fexp=916930%2C922244%2C930666%2C931342%2C932404%2C934040%2C947209%2C947215%2C952302%2C952901%2C953912%2C957103%2C957201&initcwndbps=4476250&mv=m&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&source=youtube&ms=au&sver=3&key=yt5&id=o-ACMOVxMHm7g0j1cWe6uR2fqZWHvZBdKumE2yBm0Q8dIA. It might not play.
   ... 2 more
2014-10-30 22:59:40,148 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-30 22:59:41,935 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
liru
Re: YouTube
Part 2 of the log:
2014-10-31 03:42:22,288 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?upn=cz1Rkjg1ESY&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&ipbits=0&mm=31&ms=au&mv=m&mt=1414726918&sver=3&expire=1414748540&signature=1036A1F9B3EE71C630FB656088ED33803F714781.CD027A272A302686EF9743C3DF801507881513F&fexp=916631%2C919155%2C930666%2C931022%2C932404%2C934040%2C935687%2C939109%2C942487%2C943415%2C945071%2C947209%2C947215%2C948703%2C952302%2C952706%2C952901%2C953912%2C957103%2C957201&initcwndbps=5031250&key=yt5&ip=188.25.25.138&ratebypass=yes&source=youtube&id=o-ADEH7oBJg8W17TimCZO4ivja5Wt4mztTk_a1YTItIwqt&itag=18. It might not play.
   ... 2 more
2014-10-31 04:25:24,362 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r2---sn-gqn-vu2e.googlevideo.com/videoplayback?signature=368A0AEE576DFD6C17D2B48CD92BD561D7D28431.71B27B519E62B804E4E489F56A72BBEB4AC56BB3&key=yt5&sver=3&mt=1414729409&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&expire=1414751123&upn=Fi1F09SnMM0&ip=188.25.25.138&itag=18&source=youtube&mv=m&ratebypass=yes&ms=au&mm=31&id=o-AISrIW8x-fBMSH_sOgcZp5uZiLbpXWotu5e0VeyzskR1&fexp=905639%2C916632%2C930666%2C931999%2C932404%2C934040%2C938638%2C945250%2C946102%2C947209%2C947215%2C952302%2C952901%2C953912%2C957103%2C957201&ipbits=0&initcwndbps=4702500. It might not play.
   ... 2 more
2014-10-31 09:37:29,938 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?mm=31&ip=188.25.25.138&itag=18&sver=3&ratebypass=yes&signature=633D729DEDC428F3D8A8FB93503620C9A4BAF96D.B8D3F719CE811C0386F9CBF1F67D16210D453037&id=o-AJOZxyJMz4nQtvipeAHWnThr8Spq25Nheu2pD_a2ztcS&fexp=908595%2C930011%2C930666%2C932404%2C934040%2C935639%2C936122%2C947209%2C947215%2C951814%2C952302%2C952901%2C953912%2C957103%2C957201%2C959200&mt=1414748099&upn=hVbKH3m9rmw&mv=m&ms=au&key=yt5&ipbits=0&expire=1414769848&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&source=youtube&initcwndbps=4196250. It might not play.
   ... 2 more
2014-10-31 10:20:32,561 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r2---sn-gqn-vhgl.googlevideo.com/videoplayback?mt=1414750693&mv=m&fexp=930666%2C932404%2C934040%2C947209%2C947215%2C948703%2C952302%2C952901%2C953901%2C953912%2C957103%2C957201%2C958301&ms=au&ip=188.25.25.138&itag=18&key=yt5&mm=31&upn=Ipk4R2xRLEo&id=o-AHGk0PoO6vZ7jFwBDjXMZ6zw7qw6HYMzcChhlrhQ3md9&ipbits=0&ratebypass=yes&expire=1414772431&initcwndbps=4125000&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&source=youtube&sver=3&signature=758270B56C8A8A17099A487FAD57E063F31A1512.59125D1074D76E0D2216835B2A93C250EDE8E7ED. It might not play.
   ... 2 more
2014-10-31 10:59:48,525 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Foghorn Leghorn - (1957) - Fox-Terror.mpg). Message: Unknown video file type.
2014-10-31 10:59:50,842 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Soft Machine - Holland Pop Festival Kralingen 28-06-1970.avi). Message: Unknown video codec.
2014-10-31 15:32:39,691 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-gqn-vu2l.googlevideo.com/videoplayback?sver=3&expire=1414791157&source=youtube&ms=au&mt=1414769505&mv=m&ratebypass=yes&mm=31&key=yt5&id=o-AO9A7ZX8zgnQxuX3t6uhfR-ZpceIVWjV5AbYrJ0OMSX9&upn=ryVKHV00N-c&initcwndbps=4288750&itag=18&ipbits=0&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&signature=3584388AD9F01D9FAACFF2A6308013C126A06DBC.9001F680EB952DB26708D2A1C87DA338F32DC50B&fexp=902522%2C908579%2C929305%2C930666%2C932404%2C934040%2C947209%2C947215%2C949423%2C951005%2C952302%2C952901%2C953912%2C957103%2C957201&ip=188.25.25.138. It might not play.
   ... 2 more
2014-10-31 16:15:42,791 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r12---sn-c0q7ln7y.googlevideo.com/videoplayback?signature=E6D73578A2F583663E72767BFF7505F99B29B4DC.A7DDD661ED88D3F36BE666D2E9150BFA9BFFDD02&ms=au&mt=1414772055&mv=m&upn=TDiWVJgdMjg&ipbits=0&mm=31&ratebypass=yes&id=o-AGOauvWatsSySugQqxob9EiuFiybMKgluHug1JEInVNq&fexp=914073%2C924637%2C930666%2C932404%2C934040%2C935686%2C942704%2C944902%2C947209%2C947215%2C948703%2C952302%2C952901%2C953912%2C957103%2C957201&source=youtube&expire=1414793740&initcwndbps=2986250&itag=18&ip=188.25.25.138&key=yt5&sver=3&sparams=id%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire. It might not play.
   ... 2 more
Post Fri Oct 31, 2014 8:14 pm
Re: YouTube
Not the debug log..just the you-tube video code. Please delete your post above. Long stuff like that should be enclosed in [code][/code]tags.
liru
Post Fri Oct 31, 2014 8:41 pm
Re: YouTube
jhb50 wrote:Not the debug log..just the you-tube video code. Please delete your post above. Long stuff like that should be enclosed in [code][/code]tags.
Oh, sorry about that... unfortunately I don't know how to delete it... :((( Until you let me know how, I will enclose it in [code][/ code]tags.
And which exactly is the you-tube video code? It's somewhere in that long code or where I can get it?
Many questions, sorry about that.
Regards,
Post Fri Oct 31, 2014 8:52 pm
Re: YouTube
You said you had rad my wiki :shock: !
To get a specific Youtube Video use:
where xxxxxxxxxxx is the 11 character video code that normally follows
http://www.youtube.com/watch?v=xxxxxxxxxx
when viewing Youtube videos on your PC.
liru
Post Fri Oct 31, 2014 9:10 pm
Re: YouTube
You are talking about this? http://gdata.youtube.com/feeds/api/vide ... vCbkwSS-qE
I thought you wanted some log... :)
paulmarie
Post Sat Nov 01, 2014 5:24 pm
Re: YouTube
I started using Serviio yesterday and managed to configure to view youtube feeds.
Still I'm facing an issue with some video from a youtube playlist that won't show in Serviio.
I checked serviio.log (and assume these errors could be the reason why my videos are missing) :
2014-11-01 17:23:26,448 INFO  [WebServer] WebServer starting on port 8895
2014-11-01 17:23:26,913 INFO  [Device] Updated bound IP address of Device with UUID: 361bf19d-03f1-3c7a-84c6-4d38d79a8303, bound address: 192.168.1.55
2014-11-01 17:23:26,914 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-11-01 17:23:26,914 INFO  [EventDispatcher] Starting EventDispatcher
2014-11-01 17:23:26,914 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-11-01 17:23:27,035 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.1.55, timeout = 0
2014-11-01 17:23:27,038 INFO  [RendererSearchSender] Searching for Renderer devices
2014-11-01 17:24:20,990 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r19---sn-25g7sn7y.googlevideo.com/videoplayback?itag=22&expire=1414880659&sparams=gcr%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&upn=uGIZzcGRUb4&initcwndbps=1146250&key=yt5&gcr=fr&sver=3&mv=m&mt=1414858927&ms=au&id=o-ANO9FZykm2dIKmUKhuKGGPMRlbchJnejH3gERGdC6Vfo&mm=31&source=youtube&fexp=927880%2C930666%2C932404%2C934040%2C947209%2C947215%2C952302%2C952901%2C953912%2C957103%2C957201&ip=89.89.253.143&ratebypass=yes&ipbits=0. It might not play.
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:467)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:299)
   ... 2 more
2014-11-01 17:24:21,312 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r2---sn-25g7sn7y.googlevideo.com/videoplayback?mm=31&ip=89.89.253.143&fexp=923345%2C930666%2C932404%2C934040%2C940648%2C945122%2C947209%2C947215%2C952302%2C952901%2C953912%2C955105%2C957103%2C957201%2C958400&key=yt5&sver=3&id=o-AA2mCBxkyV4CColSVmCJ051IUa5L1KY1SqYddt6a1Cpw&initcwndbps=1146250&mv=m&sparams=gcr%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&source=youtube&ms=au&upn=pub0C4I0lhM&itag=22&ratebypass=yes&gcr=fr&mt=1414858927&expire=1414880660&ipbits=0. It might not play.
   ... 2 more
2014-11-01 17:24:21,632 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://r15---sn-25g7sn7z.googlevideo.com/videoplayback?fexp=900237%2C924637%2C930666%2C932404%2C934040%2C947209%2C947215%2C952302%2C952901%2C953912%2C957103%2C957201%2C958400&initcwndbps=1146250&gcr=fr&sparams=gcr%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmm%2Cms%2Cmv%2Cratebypass%2Csource%2Cupn%2Cexpire&expire=1414880660&upn=Qkhnuktbn_g&key=yt5&source=youtube&mv=m&mt=1414858927&ms=au&id=o-ABMdz3_1UDs_1WTgNIKVTHEmRoHLcHyasCgwwlyszJfv&ipbits=0&ratebypass=yes&itag=22&sver=3&ip=89.89.253.143&mm=31. It might not play.
   ... 2 more
Any idea how to solve this?
Thanks for the great work on Serviio and Youtube plugin.
Pm
Post Sat Nov 01, 2014 10:19 pm
Re: YouTube
@liru - It also works fine for me in Windows so its not encoded. Perhaps your version of ffmpeg in Linux is too old, but I have no knowledge of Linux.
@paulmarie - without the youtube code and console entry you have used, I cannot help you.
paulmarie
Post Sun Nov 02, 2014 8:35 am
Re: YouTube
in bellow feed, two videos are not showing n Serviio ("Coldplay - A Sky Full Of Stars (Official video)" and "MAGIC SYSTEM - Magic In The Air Feat. Chawki [Clip Officiel]")
https://gdata.youtube.com/feeds/api/pla ... F6rG0m?v=2
in these two feeds, nothing is showing :
https://gdata.youtube.com/feeds/base/us ... be-profile
In the console, Max. number of feed items is set to "50" Expiry interval to "12" and Prefered quality to "High"
thanks
stefana888
Post Sun Nov 02, 2014 11:57 am
Re: YouTube
paulmarie wrote:Hi,
thanks
This is probably because Youtube use chiphered signatures in URLs with official content which this plugin doesn't handle. You can PM me for a plugin solution using latest youtube-dl standalone.
Post Sun Nov 02, 2014 2:04 pm
Re: YouTube
Yes, I've checked and they all use the scrambled signatures. All VEVO are scrambled.
liru
Post Sun Nov 02, 2014 5:09 pm
Re: YouTube
jhb50 wrote:@liru - It also works fine for me in Windows so its not encoded. Perhaps your version of ffmpeg in Linux is too old, but I have no knowledge of Linux.
I have upgraded ffmpeg to the latest version, but still no joy... :(
Any other ideas?
Many thanks.
Post Sun Nov 02, 2014 7:23 pm
Re: YouTube
These errors in your posted log indicate that you have not compiled ffmpeg as required for Linux. There are instructions elsewhere in the forum and wiki on how to do this.
liru
Post Mon Nov 03, 2014 8:48 am
Re: YouTube
Thank you very much for your help. I will try to find guidance on how to install this properly.
Regards.
programmer
Post Tue Nov 04, 2014 8:41 pm
Re: YouTube
Hi
I updated the plugin to use youtube-dl as external process.
To use, download youtube-dl from the link above, and put it anywhere in the system path (or update YOUTUBE_DL to full path inside the script).
Note that ffmpeg that comes with serviio does not support https downloads. So you'll need updated version of ffmpeg (I use the one from here
New 25/04/2015: added audio-only option. To use: set AUDIO_ONLY to true inside the script (also remember to change youtube feeds to AUDIO in serviio console).
New 04/05/2015: new Web Resource plugin, moved to new topic viewtopic.php?f=20&t=18816
Edited: added youtube-dl auto-update.
Edited: added audio-only option.
Edited: plugin moved to new topic.
Return to Available plugins
Users browsing this forum: No registered users and 137 guests
