How To Set Up Conditions in the Profile
mavigozler
Post Sat Nov 01, 2014 2:48 pm
Serviio 1.4.1.2
TV: Sony Bravia KDL-50A550R (profile set for Sony 2012)
I am having trouble with MP4 files from a certain source that often stop rendering at "98%" and require leaving the Serviio-TV connection.
To see what was stopping the rendering, I ran the "ffmpeg -i" command as advised, and after getting the error requiring the naming of an output file, I ran it again (with named output file) and got the following error:
[aac @ 04E038C0] The encoder 'aac' is experimental but experimental codecs are not enabled, add '-strict -2' if you want to use it.
When I managed to key in "-strict -2" into the output file options, the operation to recode ("encode"?) continued without error.
I am guessing that ffmpeg.exe finds files with different parameters in the media. Is there a way to set up the profile in Serviio to deal with ffmpeg errors conditionally?
Post Sat Nov 01, 2014 7:10 pm
Re: How To Set Up Conditions in the Profile
Are you PC or Linux or else?
mavigozler
Post Sat Nov 01, 2014 7:38 pm
Windows 7 Home Premium x64 SP1
Post Sun Nov 02, 2014 8:28 am
mavigozler wrote:I am guessing that ffmpeg.exe finds files with different parameters in the media. Is there a way to set up the profile in Serviio to deal with ffmpeg errors conditionally?
Could you provide information about your file (ffmpeg -i result) , to see if we can find a media type information where we should add specific option "-strict -2" ?
Otherwise, we'll always add this option for all aac audio (not sure it's a good idea)
mavigozler
Post Sun Nov 02, 2014 3:29 pm
Command and output below, with color renderings from the cmd processor
C:\Program Files\Serviio\lib>ffmpeg.exe -i "D:\test.mp4" outtest.mp4
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass
--enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --extra-libs='-lrtmp -lpolarssl -lws2_32
-lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32
--cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\test.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isomavc1
creation_time : 2014-10-04 17:09:23
Duration: 02:11:34.46, start: 0.000000, bitrate: 2125 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x800, 2027 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
handler_name : video.264#trackID=1:fps=23.976 - Imported with GPAC 0.5.0-rev4065
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 93 kb/s
creation_time : 2014-10-04 17:09:49
handler_name : GPAC ISO Audio Handler
[libx264 @ 035ED1E0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
[libx264 @ 035ED1E0] profile High, level 4.0
[libx264 @ 035ED1E0] 264 - core 133 - H.264/MPEG-4 AVC codec - Copyleft 2003-2013 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
[aac @ 052E4460] The encoder 'aac' is experimental but experimental codecs are not enabled, add '-strict -2' if you want to use it.
I hope you can find something that triggers the right setting in transcoding.
Post Sun Nov 02, 2014 5:05 pm
Why are you just reencoding the existing streams?
ffmpeg.exe -i "D:\test.mp4" outtest.mp4 is not a valid transcode and you are just rencoding AAC to AAC which is pointless.
The sony2012 profile is tested and should work but you need to use the ffmpeg command from the debug log that serviio issued to transcode your video at the point of failure which will transcode your mp4 audio to ac3. It is certainly not ffmpeg.exe -i "D:\test.mp4" outtest.mp4
