WTH happend?
keaza
Post Sat Nov 08, 2014 7:46 pm
WTH happend?
Hi im having some wierd issues with serviio ....
2014-11-06 00:24:04,568 INFO  [MediaServer] ------------------------------------------------------------------------
2014-11-06 00:24:04,568 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f+)
2014-11-06 00:24:04,568 INFO  [MediaServer] Petr Nejedly 2009-2014
2014-11-06 00:24:04,568 INFO  [MediaServer] http://www.serviio.org
2014-11-06 00:24:04,568 INFO  [MediaServer] Java 1.6.0_45-Sun Microsystems Inc.
2014-11-06 00:24:04,568 INFO  [MediaServer] OS Linux amd64 3.14.14-gentoo
2014-11-06 00:24:04,569 INFO  [MediaServer] File encoding: US-ASCII
2014-11-06 00:24:04,569 INFO  [MediaServer] Headless mode enabled: true
2014-11-06 00:24:04,569 INFO  [MediaServer] User: serviio
2014-11-06 00:24:04,569 INFO  [MediaServer] User home dir: /opt/serviio
2014-11-06 00:24:04,570 INFO  [MediaServer] Temp dir: /tmp
2014-11-06 00:24:04,570 INFO  [MediaServer] ------------------------------------------------------------------------
2014-11-06 00:24:04,817 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-11-06 00:24:04,820 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-11-06 00:24:04,893 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-11-06 00:24:04,894 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-11-06 00:24:04,918 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-11-06 00:24:04,934 INFO  [DatabaseManager] Using DERBY database language
2014-11-06 00:24:07,646 INFO  [MediaServer] ------------------------------------------------------------------------
2014-11-06 00:24:07,646 INFO  [MediaServer] License: PRO (NORMAL, id: 2ce1aa9a-0bbd-4847-ab19-9c97bd169014)
2014-11-06 00:24:07,667 INFO  [Device] Created UPnP Device with UUID: 83403509-60a4-3ac0-bae1-94340baf2344, bound address: 192.168.1.2
2014-11-06 00:24:08,045 ERROR [IndexedDiskCache] Region [thumbnails] Failure initializing for fileName: thumbnails and root directory: /opt/serviio/library/cache
java.io.FileNotFoundException: /opt/serviio/library/cache/thumbnails.key (Permission denied)
        at java.io.RandomAccessFile.open(Native Method)
        at java.io.RandomAccessFile.<init>(Unknown Source)
        at org.apache.jcs.auxiliary.disk.indexed.IndexedDisk.<init>(IndexedDisk.java:62)
        at org.apache.jcs.auxiliary.disk.indexed.IndexedDiskCache.<init>(IndexedDiskCache.java:155)
        at org.apache.jcs.auxiliary.disk.indexed.IndexedDiskCacheManager.getCache(IndexedDiskCacheManager.java:130)
        at org.apache.jcs.auxiliary.disk.indexed.IndexedDiskCacheFactory.createCache(IndexedDiskCacheFactory.java:62)
        at org.apache.jcs.engine.control.CompositeCacheConfigurator.parseAuxiliary(CompositeCacheConfigurator.java:554)
        at org.apache.jcs.engine.control.CompositeCacheConfigurator.parseRegion(CompositeCacheConfigurator.java:346)
        at org.apache.jcs.engine.control.CompositeCacheConfigurator.parseRegion(CompositeCacheConfigurator.java:267)
        at org.apache.jcs.engine.control.CompositeCacheConfigurator.parseRegions(CompositeCacheConfigurator.java:244)
        at org.apache.jcs.engine.control.CompositeCacheConfigurator.doConfigure(CompositeCacheConfigurator.java:139)
        at org.apache.jcs.engine.control.CompositeCacheManager.configure(CompositeCacheManager.java:314)
        at org.apache.jcs.engine.control.CompositeCacheManager.configure(CompositeCacheManager.java:258)
        at org.apache.jcs.engine.control.CompositeCacheManager.configure(CompositeCacheManager.java:245)
        at org.apache.jcs.engine.control.CompositeCacheManager.configure(CompositeCacheManager.java:194)
        at org.apache.jcs.engine.control.CompositeCacheManager.getInstance(CompositeCacheManager.java:122)
        at org.apache.jcs.JCS.ensureCacheManager(JCS.java:96)
        at org.apache.jcs.JCS.getInstance(JCS.java:64)
        at org.serviio.cache.AbstractCacheDecorator.<init>(AbstractCacheDecorator.java:36)
        at org.serviio.upnp.service.contentdirectory.LocalContentCacheDecorator.<init>(LocalContentCacheDecorator.java:27)
        at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.setupCache(ContentDirectoryEngine.java:140)
        at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.<init>(ContentDirectoryEngine.java:62)
        at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.getInstance(ContentDirectoryEngine.java:71)
        at org.serviio.upnp.service.contentdirectory.ContentDirectory.setupService(ContentDirectory.java:82)
        at org.serviio.upnp.service.Service.<init>(Service.java:77)
        at org.serviio.upnp.service.contentdirectory.ContentDirectory.<init>(ContentDirectory.java:38)
        at org.serviio.upnp.Device.setupServices(Device.java:180)
        at org.serviio.upnp.Device.getInstance(Device.java:118)
        at org.serviio.MediaServer.main(MediaServer.java:120)
2014-11-06 00:24:08,076 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure initializing for fileName: online_technical_metadata and root directory: /opt/serviio/library/cache
java.io.FileNotFoundException: /opt/serviio/library/cache/online_technical_metadata.key (Permission denied)
2014-11-06 00:24:08,136 WARN  [ProfilesDefinitionParser] Cannot get name of the local computer: arcadia: arcadia
2014-11-06 00:24:09,320 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-11-06 00:24:09,420 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: replacement
java.lang.NullPointerException: replacement
        at java.util.regex.Matcher.replaceFirst(Unknown Source)
        at java.lang.String.replaceFirst(Unknown Source)
        at org.serviio.profile.ProfilesDefinitionParser.getDeviceDescription(ProfilesDefinitionParser.java:378)
        at org.serviio.profile.ProfilesDefinitionParser.processProfileNode(ProfilesDefinitionParser.java:229)
        at org.serviio.profile.ProfilesDefinitionParser.parseDefinition(ProfilesDefinitionParser.java:164)
        at org.serviio.profile.ProfileManager.parseProfilesFromFile(ProfileManager.java:181)
        at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:156)
        at org.serviio.MediaServer.main(MediaServer.java:122)
2014-11-06 00:24:09,439 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2014-11-06 00:24:35,923 ERROR [ApplicationInstanceManager] arcadia: arcadia
java.net.UnknownHostException: arcadia: arcadia
        at java.net.InetAddress.getLocalHost(Unknown Source)
        at org.serviio.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:68)
        at org.serviio.MediaServer.checkForRunningInstances(MediaServer.java:283)
        at org.serviio.MediaServer.main(MediaServer.java:106)
2014-11-06 00:24:40,409 ERROR [ApplicationInstanceManager] arcadia: arcadia
2014-11-06 00:24:40,437 INFO  [MediaServer] ------------------------------------------------------------------------
2014-11-06 00:24:40,437 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f+)
2014-11-06 00:24:40,437 INFO  [MediaServer] Petr Nejedly 2009-2014
2014-11-06 00:24:40,437 INFO  [MediaServer] http://www.serviio.org
2014-11-06 00:24:40,438 INFO  [MediaServer] Java 1.6.0_45-Sun Microsystems Inc.
2014-11-06 00:24:40,438 INFO  [MediaServer] OS Linux amd64 3.14.14-gentoo
2014-11-06 00:24:40,438 INFO  [MediaServer] File encoding: US-ASCII
2014-11-06 00:24:40,438 INFO  [MediaServer] Headless mode enabled: true
2014-11-06 00:24:40,439 INFO  [MediaServer] User: serviio
2014-11-06 00:24:40,439 INFO  [MediaServer] User home dir: /opt/serviio
2014-11-06 00:24:40,439 INFO  [MediaServer] Temp dir: /tmp
2014-11-06 00:24:40,439 INFO  [MediaServer] ------------------------------------------------------------------------
2014-11-06 00:24:40,684 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-11-06 00:24:40,687 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-11-06 00:24:40,760 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-11-06 00:24:40,761 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-11-06 00:24:40,785 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-11-06 00:24:40,801 INFO  [DatabaseManager] Using DERBY database language
2014-11-06 00:24:43,169 INFO  [MediaServer] ------------------------------------------------------------------------
2014-11-06 00:24:43,169 INFO  [MediaServer] License: PRO (NORMAL, id: 2ce1aa9a-0bbd-4847-ab19-9c97bd169014)
2014-11-06 00:24:43,191 INFO  [Device] Created UPnP Device with UUID: 83403509-60a4-3ac0-bae1-94340baf2344, bound address: 192.168.1.2
2014-11-06 00:24:43,419 ERROR [IndexedDiskCache] Region [thumbnails] Failure initializing for fileName: thumbnails and root directory: /opt/serviio/library/cache
2014-11-06 00:24:43,452 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure initializing for fileName: online_technical_metadata and root directory: /opt/serviio/library/cache
2014-11-06 00:24:43,513 WARN  [ProfilesDefinitionParser] Cannot get name of the local computer: arcadia: arcadia
2014-11-06 00:24:44,684 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-11-06 00:24:44,803 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: replacement
2014-11-06 00:24:44,839 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2014-11-06 00:26:46,320 ERROR [ApplicationInstanceManager] arcadia: arcadia
2014-11-06 00:26:46,930 ERROR [ApplicationInstanceManager] arcadia: arcadia
2014-11-06 00:26:46,959 INFO  [MediaServer] ------------------------------------------------------------------------
2014-11-06 00:26:46,959 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f+)
2014-11-06 00:26:46,959 INFO  [MediaServer] Petr Nejedly 2009-2014
2014-11-06 00:26:46,959 INFO  [MediaServer] http://www.serviio.org
2014-11-06 00:26:46,959 INFO  [MediaServer] Java 1.6.0_45-Sun Microsystems Inc.
2014-11-06 00:26:46,959 INFO  [MediaServer] OS Linux amd64 3.14.14-gentoo
2014-11-06 00:26:46,960 INFO  [MediaServer] File encoding: US-ASCII
2014-11-06 00:26:46,960 INFO  [MediaServer] Headless mode enabled: true
2014-11-06 00:26:46,960 INFO  [MediaServer] User: serviio
2014-11-06 00:26:46,960 INFO  [MediaServer] User home dir: /opt/serviio
2014-11-06 00:26:46,960 INFO  [MediaServer] Temp dir: /tmp
2014-11-06 00:26:46,961 INFO  [MediaServer] ------------------------------------------------------------------------
2014-11-06 00:26:47,208 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-11-06 00:26:47,211 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-11-06 00:26:47,284 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-11-06 00:26:47,285 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-11-06 00:26:47,309 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-11-06 00:26:47,324 INFO  [DatabaseManager] Using DERBY database language
2014-11-06 00:26:49,913 INFO  [MediaServer] ------------------------------------------------------------------------
2014-11-06 00:26:49,913 INFO  [MediaServer] License: PRO (NORMAL, id: 2ce1aa9a-0bbd-4847-ab19-9c97bd169014)
2014-11-06 00:26:49,935 INFO  [Device] Created UPnP Device with UUID: 83403509-60a4-3ac0-bae1-94340baf2344, bound address: 192.168.1.2
2014-11-06 00:26:50,166 ERROR [IndexedDiskCache] Region [thumbnails] Failure initializing for fileName: thumbnails and root directory: /opt/serviio/library/cache
2014-11-06 00:26:50,199 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure initializing for fileName: online_technical_metadata and root directory: /opt/serviio/library/cache
2014-11-06 00:26:50,259 WARN  [ProfilesDefinitionParser] Cannot get name of the local computer: arcadia: arcadia
2014-11-06 00:26:50,579 WARN  [ServiioStatusService] ServerUnavailableException occured. Returning error code 503 to the REST layer. Message: Server is not available
2014-11-06 00:26:50,832 WARN  [ServiioStatusService] ServerUnavailableException occured. Returning error code 503 to the REST layer. Message: Server is not available
2014-11-06 00:26:51,028 WARN  [ServiioStatusService] ServerUnavailableException occured. Returning error code 503 to the REST layer. Message: Server is not available
2014-11-06 00:26:51,633 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-11-06 00:26:51,754 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: replacement
2014-11-06 00:26:51,776 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
Can anyone please help?
keaza
Post Mon Nov 10, 2014 3:14 pm
Re: WTH happend?
So im getting new errors now...i updated java, re installed serviio... *confused*
2014-11-07 06:19:48,686 INFO  [Device] Created UPnP Device with UUID: 83403509-60a4-3ac0-bae1-94340baf2344, bound address: 192.168.1.2
2014-11-07 06:19:49,001 WARN  [ProfilesDefinitionParser] Cannot get name of the local computer: arcadia: arcadia
2014-11-07 06:19:50,350 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-11-07 06:19:50,672 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: replacement
        at java.util.regex.Matcher.replaceFirst(Matcher.java:950)
        at java.lang.String.replaceFirst(String.java:2119)
2014-11-07 06:19:50,704 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2014-11-07 06:19:50,712 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2014-11-07 06:19:50,729 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
Post Mon Nov 10, 2014 10:45 pm
Re: WTH happend?
Looks like access rights issue,as per the log.
keaza
Post Fri Nov 14, 2014 2:56 pm
Re: WTH happend?
I have not change the permissions, nothing has changed, its just stopped working ... it worked last week
keaza
Post Fri Nov 14, 2014 3:28 pm
Re: WTH happend?
ok so, if anyone has any issues like this please check your /etc/hosts file... i added my local IP to that, and all of a sudden it works...
Users browsing this forum: No registered users and 94 guests
