Serviio problem on Raspberry Pi
akteg
Post Wed Nov 05, 2014 6:30 pm
Hi. Have Raspberry Pi model B, installed Raspbian 2014-09-09 and Serviio 1.4.1.2 encountered with some problems:
1. Serviio not start on boot. I use ssh-client to configure raspberry and when i run the server, it works as long as there is a connection. Connection drops - the server stops. I would be very grateful if someone explained to me how to run the server, independent of the ssh-connection, because i am a newbie in Linux.
2. Problem with some plugins.
Seasonvar
WARN  [FeedUpdaterThread] An error occured while parsing the online resource http://seasonvar.ru/serial-10725-Elementarno-3-season.html, will try again soon: Unexpected error while invoking plugin (SeasonVar): The operation took more than 30000 ms and has been cancelled.
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): The operation took more than 30000 ms and has been cancelled.
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:181)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:198)
   at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:185)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:108)
Caused by: java.lang.RuntimeException: The operation took more than 30000 ms and has been cancelled.
   at org.serviio.library.online.PluginExecutionProcessor.execute(PluginExecutionProcessor.java:64)
   at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:76)
   ... 4 more
Vimeo
WARN  [FeedUpdaterThread] An error occured while parsing the online resource http://vimeo.com/platigeimage/video/rss, will try again soon: Error during feed reading. Message: http://vimeo.com/platigeimage/video/rss
org.serviio.library.online.metadata.OnlineResourceParseException: Error during feed reading. Message: http://vimeo.com/platigeimage/video/rss
   at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:108)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
Caused by: java.io.FileNotFoundException: http://vimeo.com/platigeimage/video/rss
   at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:408)
   at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1888)
   at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1883)
   at sun.net.www.protocol.http.HttpURLConnection.getChainedException(HttpURLConnection.java:1882)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1455)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1439)
   at org.serviio.util.HttpClient.retrieveStreamFromConnection(HttpClient.java:181)
   at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:77)
   at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:93)
   at org.serviio.library.online.feed.FeedParser.parseFeedStream(FeedParser.java:116)
   at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:88)
   ... 4 more
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1834)
   at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
   at org.serviio.util.HttpClient.retrieveStreamFromConnection(HttpClient.java:172)
   ... 8 more
I do not understand why these plugins do not work. But the problem is clearly not in them. When I first installed serviio these versions the plugin works fine. Plus I checked on windows version - no problem. After the second installation (I changed the SD card) started to appear these errors. So I will take any help in solving this problem.
Thanks and sorry for bad english.
Post Thu Nov 06, 2014 5:37 pm
Re: Serviio problem on Raspberry Pi
the plugins may be not working anymore. Remove them if you don't need them anymore.
akteg
Post Sun Nov 09, 2014 5:47 pm
zip wrote:the plugins may be not working anymore. Remove them if you don't need them anymore.
If I understand correctly, if the plug is not working, they would not run on any version of serviio. However, as noted earlier, they work well windows version serviio, particularly windows 7.
The problem with the plugins can occur due to Java?
keaza
Post Mon Nov 10, 2014 3:19 pm
try and get the same version of java on both devices, if you still have a issue then its either the PI not being able to handle it or a plugin issue
akteg
Post Fri Nov 14, 2014 6:11 pm
keaza wrote:try and get the same version of java on both devices, if you still have a issue then its either the PI not being able to handle it or a plugin issue
I updated to the latest version of java on windows - works as before. I agree that something is wrong with raspberry pi, because before I was going to update java on it, vimeo-plugin suddenly started working. I decided to finish the theme with plugins, I think I can find an alternative seasonvar-plugin.
Until now, interested in the solution for the first question. Thanks.
Users browsing this forum: No registered users and 91 guests
