Problem with mp4 files on Samsung C6540
bs_lcd
Post Tue Feb 15, 2011 8:58 pm
I am trying to play videos from my Samsung WB600 camera on my Samsung C65340 (similar spec to C6530)
The files are stuttering/choppy on the TV - but play ok on PC using Qucktime and VLC (but not Windows Media Player)
Details :
C:\Program Files (x86)\Serviio\lib>ffmpeg -i sam75.mp4
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Seems stream 0 codec frame rate differs from container frame rate: 60000.00 (600
00/1) -> 30.00 (30/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'sam75.mp4':
major_brand : MSNV
minor_version : 19464262
compatible_brands: MSNVmp42isom
creation_time : 2011-02-11 09:04:56
Duration: 00:00:12.83, start: 0.000033, bitrate: 9045 kb/s
Stream #0.0(jpn): Video: h264, yuv420p, 1280x720, 8909 kb/s, 30 fps, 30 tbr,
30k tbn, 60k tbc
Stream #0.1(jpn): Audio: aac, 44100 Hz, stereo, s16, 127 kb/s
Post Wed Feb 16, 2011 8:20 am
Re: Problem with mp4 files on Samsung C6540
Check the peak video bitrate with Bitrate Viewer
bs_lcd
Post Wed Feb 16, 2011 6:50 pm
Bitrate Image attached
Post Thu Feb 17, 2011 7:52 am
Ok peak video bitrate 12288Kbps is not too high
Could you check with MediaInfo tools the h264/AVC, profile and level ?
bs_lcd
Post Thu Feb 17, 2011 6:41 pm
MediaInfo :
Complete name : C:\Documents and Settings\XPMUser\Desktop\SAM75.MP4
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 13.8 MiB
Duration : 12s 833ms
Overall bit rate : 9 046 Kbps
Encoded date : UTC 2011-02-11 09:04:56
Tagged date : UTC 2011-02-11 09:04:56
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 8 910 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.322
Stream size : 13.6 MiB (98%)
Language : Japanese
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 12s 817ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 200 KiB (1%)
Language : Japanese
Post Thu Feb 17, 2011 7:34 pm
AVC Format profile : Main@L4.0
Its normal, I do not see what happens
Post Thu Feb 17, 2011 8:54 pm
are you on wired or wireless network? the MP4 playback requires a lot of requests for chunks of the file and if they cannot be served quickly enough it might cause the stuttering
bs_lcd
Post Fri Feb 18, 2011 7:38 pm
Hi
Thanks to the both of you for your help
It is a wired connection
I have done some more investigating - which just seems to add to my confusion
The video plays ok :
- on VLC and Quicktime on PC
- on the actual Camera
- on TV when Camera is connected directly to TV via micro-HDMI cable
The video does NOT play :
- using DLNA - i.e. Serviio and 'play to'
- using an SD-Reader USB stick - plugging the camera SD card into the stick and then into TV
- copying files onto a USB stick and plugging into TV
- using Windows media player on PC
So the video works in some cases but not others - I am totally confused
Post Sat Feb 19, 2011 8:13 am
You could try to remux you files into m2ts with TsMuxer tools.
