Kathrein UFS 924
Negeos
Post Sat Nov 15, 2014 1:14 pm
Kathrein UFS 924
i am new at this forum.
I have a request for "Kathrein UFS 924". http://www.kathrein.de/satelliten-und-t ... /20210209/
I did not find something about this.
Does anyone have a profile for this reciever?
In my ServiioConsole it is defined as "unrecognized devices". So i can see the folders an files but can`t start them.
I testet it with movies, pictures and music. I found everything but can`t play it.
Does anyone have a solution?
(I hope you understand my bad english :) )
With best regards
Andy
Post Sat Nov 15, 2014 6:00 pm
Re: Kathrein UFS 924
Look at my signature links, then could you provide format supported by your device with INTEL Upnp Tool ?
Negeos
Post Sat Nov 15, 2014 8:47 pm
You have received a message.
Thank you very much for your help.
Andy
Post Sun Nov 16, 2014 8:51 am
Please post answer here. Some other members could read and make a different feedback than me.
According to your private message, its strange
The field "Sink" is empty.
The field "Source" there is :
http-get:*:image/gif:*,http-get:*:image/jpeg:*,http-get:*:audio/mpeg:*,http-get:*:video/mpeg:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/avi:*,http-get:*:video/wmv:*,http-get:*:audio/wma:*
In specification its seems that this device should implement Upnp-Client (media from NAS,etc)
But according to INTEL Upnp Tools, it seems that your device act as an upnp server, not an upnp player.
What is your serviio version, free, trial or pro ? Could you check with MediaBrowser that you have media in serviio library.
Negeos
Post Sun Nov 16, 2014 11:58 am
thanks for you reply.
I use the free version of serviio.
The server is working fine. I have a Samsung UE40H6270 TV. He can play the files on the server witout any problems.
With the Kathrein i can see the files. But i can`t play them.
Post Sun Nov 16, 2014 12:22 pm
Negeos wrote:With the Kathrein i can see the files. But i can`t play them.
Ok,
Do you try to change profile for your device on serviio console ? Try with "DirecTV HD-DVR", "WDTV Live" ... profiles
Negeos
Post Sun Nov 16, 2014 12:47 pm
Yes, i changed the profile but they do not work.
So i think i need a own profile for the receiver?
Negeos
Post Wed Nov 19, 2014 5:08 pm
the problem is still there.
Nobody who can help me? :(
Post Wed Nov 19, 2014 5:28 pm
Negeos wrote:Nobody who can help me? :(
Do you also try with Xbox360 profile ? it's a "simple Upnp profile".
Could you enable detailed logging and restart service service (not server) and post log here ?
Negeos
Post Wed Nov 19, 2014 5:44 pm
thanks for your reply.
With the profile XBOX360 the problem is still alive.
I enabled the detailed logging. (in the attachment)
I can`t see any errors. But i think you will see more then i. :)
Andy
Post Wed Nov 19, 2014 8:23 pm
Could you edit ./Serviio/config/profiles.xml file ?
Then add the following block just before the last </Profiles> element, then save, then restart serviio services or reboot PC.
Check on serviio console that serviio automatically select the Kathrein profile for your device.
   <Profile id="Kathrein" name="Kathrein UFS 924" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <User-Agent>.*stm24_0202-mb680.*</User-Agent>
         </HttpHeaders>
      </Detection>
      <ProtocolInfo>simple</ProtocolInfo>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="12000" targetACodec="ac3">
            <Matches container="*" />
Negeos
Post Thu Nov 20, 2014 12:42 am
thanks für the profile. The console does not selected the profile automatically. So i change it but it is not working.
Same problem.
I don`t know what we can do.
It is mysterious that i can see all files but can`t play them. Not even pictures or music.
Post Thu Nov 20, 2014 12:12 pm
Do you try with another media server like Windows Media Player ?
Negeos
Post Thu Nov 20, 2014 2:40 pm
Yes i tested this with the media server "Plex"
There i can play the videos but they are haltingly and after a view seconds the video is closed.
So that shows me, that the receiver can play the videos.
Post Sun Nov 23, 2014 9:32 pm
There is not request for the files in the log. Not even the thumbnails.
You could contact the manufacturer for help and see if they test with Serviio or what server they recommend.
Negeos
Post Wed Nov 26, 2014 10:44 am
They wrote that the receiver is suitable for the home network but they can not recommend a server.
The original post is:
das Gerät UFS 924 kann ins Heimnetzwerk eingebunden werden.
Eine Anleitung über die Einrichtung, mögliche Funktionen und wichtige Hinweise, finden Sie
in einer Anleitung unter folgendem Link:
Diese ist auch für Ihr Gerät geeignet.
http://www.kathrein.de/fileadmin/media/ ... 012-09.pdf
Vermutlich kann das Gerät UFS 924 die vorhandenen Dateien nicht erkennen bzw. öffnen.
Um dies zu prüfen, speichern Sie einzelne Dateien auf einen USB Stick und prüfen nun,
ob das Gerät diese erkennt.
Eine spezielle Geräteempfehlung können wir Ihnen nicht nennen.
If u need a translation, let me know.
